It is much quicker to download the update on a phone and then connect the phone to the car to transfer. It takes about 30 minutes to transfer and then a further 20 minutes or so for installation.Wyldie85 wrote: ↑Wed Nov 04, 2020 11:26 pm Did a check today and it said mine was available. It said it was preparing the update but didn’t begin downloading or installing it on the twenty minute drive home this evening...
Seems there’s a fair bit in the download as it states in the release notes and various forums online. Will have a try this weekend. See if it finally updates.
OTA coming soon in Europe
2023 BMW Z4 G29 sDrive 20i M sport in Thundernight
2020 BMW S1000 XR TE, ice grey
Steps:Wyldie85 wrote: ↑Wed Nov 04, 2020 11:26 pm Did a check today and it said mine was available. It said it was preparing the update but didn’t begin downloading or installing it on the twenty minute drive home this evening...
- downloaded update to phone
- connected phone via WIFI to BMW exposed wifi network
- software was send from phone to car (but had to let motor running as else it switched off after a few minutes) (took like 30-40 minutes)
- then i could switch off the engine and the update got installed (another 15-20 minutes)
- then few hours to figure out how that 'android auto' worked from my Motorola smartphone (in the end it worked, even wireless)
- Wyldie85
Thanks guys. I’ve since downloaded it to my phone and it says it’s ready to go. Will do it the way you’ve suggested.
Thanks for the input guys, I didn't realise that the engine had to be running to transfer the files from the phone to the car....timings were around the same as Bart9140 said.
Clever stuff isn't it!!
I find it interesting that everyone seems to be getting version 07/2020.56 from the OTA update. My car was in getting the KAFAS camera replaced and my software was updated to 07/2020.60. I am curious as to what the slight revision is for?
....just a quickie, once you've downloaded the update files from your phone to the car there is about a 10 minute wait before your car informs you that the update is ready to start....I was sat there thinking I'd done something wrong!!
Any tips for getting my phone connected to the wifi? It keeps connecting and disconnecting so won't transfer the download. Oneplus6 Phone. Download in the car is at 14% and I'm not driving much at the moment so don't want to sit with it idling for hours just to download the rest.
Not sure if it helps but I followed the procedure on this video to connect my phone to the cars wifi....https://youtu.be/7avD14vNiwg
I let the car download it and installed when told to do so. Hassle free and no problems.
- raven
im on version 07/2020.30 when checking for updates i get nothing, other people in my country are getting higher version numbers, so I think it doesnt push minor updates, there's probably some version log you can scroll through inside the car somewhere.TheGingerOneNI wrote: ↑Sat Nov 07, 2020 3:01 am I find it interesting that everyone seems to be getting version 07/2020.56 from the OTA update. My car was in getting the KAFAS camera replaced and my software was updated to 07/2020.60. I am curious as to what the slight revision is for?
update, nevermind, just got it while doing my satnav update
2019 BMW Z4 G29 M40i @600hp - IG: ZZZZ_M40i
- Sladester100
Yes you can.Ledg wrote: ↑Fri Oct 30, 2020 6:11 pmIt easy easy just takes forever to send the update to your car. Then when it’s finished doing that you need to have 20mins spare where you can leave the car with the key in and not need to use it as it won’t start while it’s updating and you can’t lock it.
You have to start the update, wait until it has started, then you can exit and lock. The alarm won’t arm and the iDrive will stay on.
Yeah I tried it remote to start and it was slow as hell. Downloaded to the app using home WiFi, was over a gb. Then next time got in car, told it to transfer then drove 20 mins to work and it was ready to install when I parkedWyldie85 wrote: ↑Wed Nov 04, 2020 11:26 pm Did a check today and it said mine was available. It said it was preparing the update but didn’t begin downloading or installing it on the twenty minute drive home this evening...
F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies :thumsup:
G29 M40i First Edition Frozen Orange
- Wyldie85
Downloading to the phone was much better. Got in the next time and it was done in no time.
Finally got mine downloaded and installed last week. First time driving since and spotify is much LESS reliable than before. Patchy playing tracks and takes its time to change between artists. A bit of a backward step really from where it was before
I like the voice command to lower windows. Apart from that, nothing else I've noticed so far
- Obs-Com
Not sure if I’ve got this wrong as don’t recall seeing it before. Since the update the green “side lights on symbol” is showing up on the dash. I always have the lights set at auto and daytime running lights at default setting but can’t recall seeing the green symbol before?
2011-14: E89 2.3sDrive
2014-16: E89 35is - Valencia Orange X2 (gone but not forgotten)
2016-17: F33 440i
2017-17: E85 2.5si
2017-19: F87 M2 - Long Beach Blue DCT (Stunning)
2019-23: G29 M40i First Edition (more stunning than the M2)
2023-??: G23 M440i
2016-17: F33 440i
2017-17: E85 2.5si
2023-??: G23 M440i
I also noticed thatObs-Com wrote: ↑Tue Nov 17, 2020 7:23 pm Not sure if I’ve got this wrong as don’t recall seeing it before. Since the update the green “side lights on symbol” is showing up on the dash. I always have the lights set at auto and daytime running lights at default setting but can’t recall seeing the green symbol before?
