Looking at the E86 one it curves towards the disc as well
https://cdn11.bigcommerce.com/s-dals72e ... 00.JPG?c=2
https://cdn4.pelicanparts.com/techartic ... /pic01.jpg
Yeah that's pretty much the same as the rears on the E89. Both those pics are rears also.Flyingfifer wrote: ↑Mon Jun 03, 2019 5:47 pmLooking at the E86 one it curves towards the disc as well
I do like the car otherwise if they could fix the problem with the brakes I would be happy. In any case it would cost me a lot of money to take it back.
Yes, that may work on the rear brakes if it stays in place. Might be worth a try. Thanks for offering this solution flybobbie.flybobbie wrote: ↑Fri Jun 07, 2019 6:49 pm I wonder if a edging rubber with a lip could be fitted.
This sort of rubber.
https://www.ebay.co.uk/itm/Leaf-Fin-Sea ... Swj4dbmVlR
https://www.ebay.co.uk/itm/Large-Vertic ... 0005.m1851
https://www.ebay.co.uk/itm/Large-Expose ... 0008.m2219
Thanks for sharing EwazixEwazix wrote: ↑Fri Jun 07, 2019 7:54 pm Has some top things you need to know as an M driver including about stones in the dust shield
Looks like the FX8 ones curve over as normal.
https://youtu.be/rgVLBT0HWWE?t=57
............... WTF is that design!?!Jim S wrote: ↑Thu Jun 06, 2019 12:57 pm This photo of the front M Sport brake assembly clearly shows what the problem is. The wide open top is a magnet for catching stones and the bottom of the shield bends in towards the disc closing the gap and trapping the stone. The bottom of the shield can't be bent outwards because of the track rod end which is right up against the shield.
Shocking, not fit for purpose. BMW should be ashamed of it.Flyingfifer wrote: ↑Fri Jun 07, 2019 10:08 pm............... WTF is that design!?!Jim S wrote: ↑Thu Jun 06, 2019 12:57 pm This photo of the front M Sport brake assembly clearly shows what the problem is. The wide open top is a magnet for catching stones and the bottom of the shield bends in towards the disc closing the gap and trapping the stone. The bottom of the shield can't be bent outwards because of the track rod end which is right up against the shield.
