Winter tires?
Discussing the current generation Z4
raven
Winter tires?
Post by raven » Mon Nov 16, 2020 1:04 pm
Hello,
I was wondering, is anyone here still using the car during winter? If yes, do you place winter tires and wich ones?
I currently have the default bmw ones "Continental Winter Contact TS830P" but gripwise the difference compared to the michelin summer tires is huge especially when its losing grip quite often when accellerating even when at speed.
Does anyone have a good alternative set?
2019 BMW Z4 G29 M40i @600hp - IG: ZZZZ_M40i
millview22
Winter tires?
Post by millview22 » Mon Nov 16, 2020 1:21 pm
raven wrote: Mon Nov 16, 2020 1:04 pm Hello,
Winter tyres tend not to be as effective when the temperature rises above 7C. In warmers temperatures, they can feel a bit flabby under acceleration compared to summer tyres.
I usually change to winter tyres between December and March; if there is any dodgy weather they immediately show their worth. I have wheels and tyres sourced from BMW; my dealer stores the wheels and changes them when I ask (for a fee!). I can't recall if they are Continentals, but I will be getting them changed after the lockdown.
2023 BMW Z4 G29 sDrive 20i M sport in Thundernight
2020 BMW S1000 XR TE, ice grey
mr.tourette
Winter tires?
Post by mr.tourette » Mon Nov 16, 2020 1:27 pm
Michelin Cross Climates if you want an all year round tyre that copes with everything winter can throw at it and still crack on in the summer...an out and out summer tyre will obviously out perform it but they are still a great tyre
raven
Winter tires?
Post by raven » Mon Nov 16, 2020 3:08 pm
millview22 wrote: Mon Nov 16, 2020 1:21 pm dealer stores the wheels and changes them when I ask (for a fee!). I can't recall if they are Continentals, but I will be getting them changed after the
Here bmw works with fixed dates, usually its about the same time as the summer/wintertime change, a few weeks before and after .
During lockdown they force the dealerships to close except for urgent repairs. I had the same problem during last lockdown, so i decided to switch as soon as possible, so i didnt have to do all winter with my summer tires.
Bart9140
Winter tires?
Post by Bart9140 » Mon Nov 16, 2020 4:10 pm
raven wrote: Mon Nov 16, 2020 3:08 pm
And do you have special winter rims?
Not that the need for winter tyres is urgent as with corona i am not driving an awfull lot :)
But in case i would need them, i want to still have 19´...so wondered if your winter tyres have new wheels to.
Pbondar
Winter tires?
Post by Pbondar » Mon Nov 16, 2020 4:12 pm
I use Conti TS830 / TS850 on the E89/F56/XC70..
As they are a pure play winter tyre in the dry they won't compare to a summer tyre on a warm day..
For what they are designed to do, which is drive well in very cold n wet conditions with maybe light snow they are very good..IMHO
If you need a tire that performs well above 8c then as others have said an all seasons tyre maybe a better choice..
The one time I id drive the Z4 at around 19c-21c on TS830s in 'hooning' mode they went off very quickly and were wearing out v fast..
raven
Winter tires?
Post by raven » Thu Nov 19, 2020 4:06 pm
Bart9140 wrote: Mon Nov 16, 2020 4:10 pm Not that the need for winter tyres is urgent as with corona i am not driving an awfull lot
Yes they had one set of 18" winter rims available on the bmw site, they came with the continental tires
798 M, Orbitgrey
2019-11-17 19.31.45.jpg (81.1 KiB) Viewed 1816 times
raven
Winter tires?
Post by raven » Thu Nov 19, 2020 4:11 pm
Pbondar wrote: Mon Nov 16, 2020 4:12 pm I use Conti TS830 / TS850 on the E89/F56/XC70..
They dont feel nearly as grippy as the wintertires i had on my 4 gran coupe, even when it is colder and or snowing,
but maybe its just the weight difference or the horsepower/torque difference and something i need to get used to
Ewazix
Winter tires?
Post by Ewazix » Thu Nov 19, 2020 7:36 pm
mr.tourette wrote: Mon Nov 16, 2020 1:27 pm Michelin Cross Climates if you want an all year round tyre that copes with everything winter can throw at it and still crack on in the summer...an out and out summer tyre will obviously out perform it but they are still a great tyre
+1 for Cross Climates, I've had them on two cars winter and summer, they worked as well as my previous Mud & Snow winter-only set in the snow/ice and drove and wore very well in the summer. Expensive but worth it.
2018 Cooper S Countryman
Fiesta Ecoboost
Beeacon
Winter tires?
Post by Beeacon » Fri Nov 20, 2020 1:46 pm
I have a set of Michelin Pilot Alpin 4 on my E89 for winter, and while they're fantastic in the dead of winter, I think I wouldn't go for a full winter tyre in the UK again. They are only actually useful for the coldest portion of the year (around 2 months or so when its below 7c). Instead, I think I would next go for CrossClimates as my winter tyres, and maintain a set of full summers too. CrossClimates will perform better in the wet winters we usually get.
Current: Still thinking...
Past: 2009 BMW Z4 35i sDrive DCT
Past: 1997 BMW Z3 2.8 wide boy
millview22
Winter tires?
Post by millview22 » Fri Nov 20, 2020 5:28 pm
Yes, winter rims with winter tyres...
Beeacon
Winter tires?
Post by Beeacon » Fri Nov 20, 2020 8:17 pm
millview22 wrote: Fri Nov 20, 2020 5:28 pm
raven wrote: Mon Nov 16, 2020 3:08 pm Here bmw works with fixed dates, usually its about the same time as the summer/wintertime change, a few weeks before and after .
I have winter rims with mine. The cost of swapping the tyres over every season will run you around £100 a change which will quickly rack up doing it twice a year. As it is a very grimy time of year, with lots of road salts that can be corrosive on your wheels, it would be best to go for a painted finish rather than diamond cut, as this will hold up to the seasonal muck for longer before needing to be refurbished (as well as being much cheaper to refurbish too).
F1SpaceMonkey
Winter tires?
Post by F1SpaceMonkey » Sun Nov 22, 2020 2:17 pm
this is a good channel to watch before going for winters. If you see more cold rain and not much snow crossclimates are the way to go.
https://www.youtube.com/watch?v=gHph1mDtCbQ&t=1271s
EmGill
Winter tires?
Post by EmGill » Tue Nov 24, 2020 2:06 pm
"Yes, winter rims with winter tyres..."
I second that. Don't just go for winter tires, purchase a whole matching set as well.
Ledg
Winter tires?
Post by Ledg » Sat Nov 28, 2020 3:42 pm
raven wrote: Thu Nov 19, 2020 4:06 pm
798 M, Orbitgrey
My winter wheels finally came into my local Bmw today. Nice not to be getting to much salt on my diamond cut wheels.
