Satnav issue!
Alpina Specific discussion
pvr
Satnav issue!
Post by pvr » Fri Jun 10, 2016 4:02 pm
markeg wrote:The lead runs through to the light unit above the rearview mirror in mine, and there was an f-connector in there so replacement was simple - but IIRC cj10jeeper mentioned that some cars have the antennae behind the dashboard?
Correct, on my retrofits that is where I put mine as well - on the metal brackets behind the radio.
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Jeep
srhutch
Moderator
Moderator
Satnav issue!
Post by srhutch » Fri Jun 10, 2016 7:15 pm
As PVR states, the retrofit location is in the dash behind the instrument panel, which is where I put mine.
Pvr obviously was cutting corners again. :poke:
zedwheels
Satnav issue!
Post by zedwheels » Fri Jun 10, 2016 8:08 pm
Its all getting a little to complicated for my skill level so I will get a Garmin for when it plays up! :oops:
zedwheels
Satnav issue!
Post by zedwheels » Fri Jun 10, 2016 8:14 pm
GPS 1.JPG (42.22 KiB) Viewed 2372 times
GPS 2.JPG (38.39 KiB) Viewed 2372 times
These are a couple of pics I took of whats behind the plastic cover of the rear view mirror!
markeg
Satnav issue!
Post by markeg » Fri Jun 10, 2016 9:36 pm
Have you checked in the light module near the rear view mirror? Mine is not in the plastic part of the rear view mirror, but under the interior light module (the lights pop out)...
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
zedwheels
Satnav issue!
Post by zedwheels » Sat Jun 11, 2016 11:11 am
markeg wrote:Have you checked in the light module near the rear view mirror? Mine is not in the plastic part of the rear view mirror, but under the interior light module (the lights pop out)...
Ah, no I haven't had a look in there but I shall.
