Alpina steering wheel
Alpina Specific discussion
Phil a
Post by Phil a » Sun Jan 20, 2019 7:12 pm
Hi can anyone give me some info on removing the steering wheel, is it a simple disconnect battery and then prise of the air bag or is there more to it any info much appreciated
markplant
Post by markplant » Sun Jan 20, 2019 7:25 pm
Don't prise it off
If you feel the back of the spokes you should find a hole that I believe has a torx head in it
srhutch
Moderator
Moderator
Post by srhutch » Sun Jan 20, 2019 7:40 pm
markplant wrote: Sun Jan 20, 2019 7:25 pm Don't prise it off
Nearly, you need a flat bladed screwdriver to push into the holes either side to press the spring clip in to release the airbag. You can do one at a time.
Hold the screwdriver so the tip is horizontal, as the spring is a vertical lever in effect.
firebobby
Post by firebobby » Sun Jan 20, 2019 7:46 pm
+1 :thumbsup:
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
markplant
Post by markplant » Sun Jan 20, 2019 8:36 pm
srhutch wrote: Sun Jan 20, 2019 7:40 pm
Thanks steve
Zoomer
Post by Zoomer » Sun Jan 20, 2019 9:13 pm
As above except it always seems to be a right bugger to get it to come off. Don’t forget the connectors under the airbag before you remove the steering wheel
Sterling Grey 3.0i E85 Black Heated Leather M sports seats , 224's ,Sat Nav, Bluetooth, Xenons, PDC, Gaptech ,Cruise and a nice warm garage. NOW GONE
Silver 3.0i Z4 NOW GONE
bz4kev
Post by bz4kev » Sun Jan 20, 2019 9:24 pm
Phil a wrote: Sun Jan 20, 2019 7:12 pm Hi can anyone give me some info on removing the steering wheel, is it a simple disconnect battery and then prise of the air bag or is there more to it any info much appreciated
Push flathead screwdriver in top hole marked and push spring loaded as marked best to disconnect battery for 30 mins just in case airbag deployment best to be safe :thumbsup:
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
Phil a
Post by Phil a » Sun Jan 20, 2019 9:45 pm
Thanks for the help just checked Markplant was the correct one
firebobby
Post by firebobby » Sun Jan 20, 2019 10:01 pm
Phil a wrote: Sun Jan 20, 2019 9:45 pm Thanks for the help just checked Markplant was the correct one
Not unless they changed the design. Or you have a non standard wheel fitted. I would double check that because the flat screw driver method is the way to get the air bag off on these cars, as far as I know :|
Toyota MR2 NA 1995
Mini 1000 1981
srhutch
Moderator
Moderator
Post by srhutch » Sun Jan 20, 2019 10:10 pm
firebobby wrote: Sun Jan 20, 2019 10:01 pm
Guessing the OP has just decided to remove the spoke covers then, leav8ng the airbag in place.
firebobby
Post by firebobby » Sun Jan 20, 2019 10:14 pm
srhutch wrote: Sun Jan 20, 2019 10:10 pm
Sounds like it Steve :wink:
Toyota MR2 NA 1995
Mini 1000 1981
bz4kev
Post by bz4kev » Sun Jan 20, 2019 10:27 pm
Thought he was removing steering wheel not the plastics?? Removing the plastics will not remove the wheel !!!! Very confused now 🥴
markplant
Post by markplant » Sun Jan 20, 2019 10:40 pm
Beginning to wish I'd not replied now
Phil a
Post by Phil a » Sun Jan 20, 2019 11:16 pm
I watched the video on YouTube about removing the wheel on a z4 but my car hasn’t got the holes either side of the wheel too put the screwdriver in but it has the screws on the back of the spokes ...I’ve got a bloody headache
Phil a
Post by Phil a » Mon Jan 21, 2019 12:19 am
Apologies found the holes we are not all perfect
