Hydrogen Carbon engine clean
- AlpinaJr
Hi,
As anybody had this carried out on their Roadster S? If so any positives or negatives?
Alpina RS Lux No 156, Sapphire Metallic Black / Renault Clio V6 / Ford Racing Puma / Abarth 695 Edizione Maserati
- Ewazix
I think it's been discussed before, the consensus was that the science smelt like BS mixed with old snake oil. Even this firms own explanation of the chemical process and caveats about how effective it MIGHT be are very unconvincing
https://www.engineclean.uk/how-it-works/
The Advertising Standards Authority have also upheld a complaint about the product because there was no evidence that it worked on current cars, the test data had come from 1977 and wasn't independent, and a clean done on a 25 year old Celica with 175k miles was ruled as not being representative.
As a result the ASA ruled that "UK Carbon Cleaning are not allowed to advertise with claims that their product saved fuel and increased MPG, prolonged engine life, restored engine performance, reduced emissions, removed carbon deposits from all engine types, prevented wear of engine parts, reduced intermittent acceleration cut-out and engine noise, reduced exhaust fumes, facilitated vehicle inspections for pollution tests (MOT test) or increased engine lifespan"
- or put more succinctly they are banned from claiming that it does anything at all!
https://www.asa.org.uk/rulings/matthew- ... 57215.html
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- AlpinaJr
Cheers Ewazix,
That's probably the most comprehensive response I've ever come across. But in a nutshell the carbon cleaning process does sweet FA?
- Tcochrane92
It makes your wallet lighter!
Current: Imola Red 400bhp 640d & Ocean Blue BMW S1000XR Sport SE
Past: Silver Grey Z4MR, Silver Grey Z4C & Titan Silver Z4 3.0i
- Ewazix
No probs
I did look at it a few years ago when I had a previous model Cooper S that was suffering with carbon fouling which is common on that model. It actually needed blasting with powdered walnut shell to shift it. If you think about it logically removing carbon deposits from an oven requires acid and scraping, temperatures and pressures are higher in the cylinder head so sloshing some non corrosive mumbo jumbo fluid isn't going to do much good. Carbon deposits don't seem to be a huge issue on these engines, so apart from using decent fuel there and giving it an occasional 'Italian tune-up' there isn't much to do regarding carbon.
Fiesta Ecoboost
Fiesta Ecoboost
OnlineR60BBA
Which Z4 do you have?
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2001 Z3 E36/7 2.2i San Remo Individual
Gone: 2015 F21 116d M Sport
Gone: 2012 A3 Sportback 1.2TFSI
- TomK
Long shot but maybe a Roadster S
OnlineR60BBA
They’re all roadsters, most of which have an S somewhere in the model name.
OP tell us the engine you have so that I can advise you as to whether carbon cleaning is worth it or not.
- TomK
Alpina only did one engine for these cars. Keep up at the back
- JamieZ4C
As this is the Alpina section and the OP's username has Alpina in it, I'm going out on a limb here... I think he has an Alpina Roadster S!
It's a 3.4 version of the S52 from memory.
All explained here...
https://en.m.wikipedia.org/wiki/Alpina_Roadster_S
- JamieZ4C
- TomK
But I'm intrigued to hear your advise (sic) on the merits of carbon cleaning between presumably what you thought would be a 2 litre 4 pot or 3litre 6. I'm guessing you must work in the field that we should take note of your advice
OnlineR60BBA
Hmm fair enough guys.
Seems like the engine (3.4-litre E5/2) is port injection and thus not worth a carbon clean as a good quality fuel such as V Power would already keep the exhaust and intake valves free from carbon deposits.
As a general rule of thumb, carbon cleaning is only worth it on direct injection engines such as those in the some of the E89 models and all of the G29 gen.
- buzyg
Won't be using that then.Ewazix wrote: ↑Wed Jun 12, 2019 8:05 am I think it's been discussed before, the consensus was that the science smelt like BS mixed with old snake oil. Even this firms own explanation of the chemical process and caveats about how effective it MIGHT be are very unconvincing
Back in the day, the navy used 'carbo blast' (crushed walnut shells) to clean the compressor blades on marine gas turbines. It was quite challenging to carry out the procedure on gas turbine driven generators because the carbo blast was burned off in the combustion chamber which caused the rotational speed to increase. There was a strong possibility that the lights would go out when the generator oversped and tripped!
Start the day with a smile, get it over with.
Bog standard 2007 3.0si manual E86 in Montego blue with black leather, currently fitted with MV2s
