Pergola build
Online
Pergola build
That is an excellent job, you should be well chuffed with yourself, especially the centre mitred notch (Nitrix' solution ). I would not have thought of that and would have had the router out.
Timber is far from cheap anymore; still it doesn't grow on trees I suppose
You could use wood dye on the 2x1 but you will never get it to match properly.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Pergola build
Thankyou.Pondrew wrote: ↑Tue Jun 15, 2021 9:49 am That is an excellent job, you should be well chuffed with yourself, especially the centre mitred notch (Nitrix' solution ). I would not have thought of that and would have had the router out.
A router is next on my list
I did contact a more local sawmill about getting the 2x1 in Larch or Douglas fir but didn’t hear back from them. If I can get some then I’ll swap it over but probably just live with it.
I’ve learnt a lot doing this and got a bit more confidence to tackle things in the future.
2011 E89 sDrive20i
Online
Pergola build
I did that but maybe took it a bit far. I made a coffee table having done no woodworking before, before I knew it I had made this: Then when I had finished that I did this: It's got a bit out of hand for me!ihadablackdog wrote: ↑Tue Jun 15, 2021 10:45 am I’ve learnt a lot doing this and got a bit more confidence to tackle things in the future.
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Online
Pergola build
Doh tried to edit!
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
OnlineChippie
Pergola build
If you’re planning anything major I’d suggest getting a 1/2’ router,
Something like this
https://www.screwfix.com/p/trend-t7-ek- ... 230v/307kg
If your only going to be doing a little moulding then a 1/4’ router would do, they aren’t as bulky or heavy as a 1/2” but obviously don’t have the guts or depth of plunge for doing deep cuts, which ever you get, as with the planer don’t be tempted to take too much out in one go
Pergola build
Wow! Bit of a jump from coffee table to house!!Pondrew wrote: ↑Tue Jun 15, 2021 12:53 pmI did that but maybe took it a bit far. I made a coffee table having done no woodworking before, before I knew it I had made this:myrtle house 2012 050.JPGmyrtle house 2012 049.JPGmyrtle house 2012 048.JPGihadablackdog wrote: ↑Tue Jun 15, 2021 10:45 am I’ve learnt a lot doing this and got a bit more confidence to tackle things in the future.
Looks awesome!!!!
The closest I’ll get to that is by putting a roof and some walls on the pergola!
It started with a raised veggie planter and now the pergola, which to be fair is quite a jump, but can’t see anything bigger on the horizon….saying that, I did tell Deb that I’d make her a walk in greenhouse!
2011 E89 sDrive20i
Pergola build
Thankyou. It would only be occasional use and probably small scale, so likely to start with 1/4 inch and experiment, I guess I won’t really know until I try one.Chippie wrote: ↑Tue Jun 15, 2021 1:00 pmIf you’re planning anything major I’d suggest getting a 1/2’ router,
Something like this
2011 E89 sDrive20i
Online
Pergola build
See, you're on the slippery slope. I made the kitchen above as I'm a tight-ar*e and a bespoke solid oak kitchen to buy was stupid money, so bought the machinery and had a go. I sold the machinery after for good money, then the chance to build the house came up. So ended up buying a whole new set of woodworking machinery!ihadablackdog wrote: ↑Tue Jun 15, 2021 2:01 pm It started with a raised veggie planter and now the pergola, which to be fair is quite a jump, but can’t see anything bigger on the horizon….saying that, I did tell Deb that I’d make her a walk in greenhouse!
Regarding routers; as Chippie above says a 1/4 router (I had a Trend T3 but it's now bust) is good for most things but a 1/2" is good for pretty much everything (as they come with 3/8" and 1/4" collet too) but can be a bit of a handful. Bigger routers can be undermounted in a router table if you are getting into serious work aswell.
www.axminstertools.com are the ultimate toy shop for anything woodworking IMO
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Pergola build
The house is good for a 1st attempt
My problem is space…..most things done on the patio which isn’t completely flat (hence some of my mitre saw cuts are a bit p1ssed ). Garage is full of stuff, mainly a commercial treadmill so need another shed….and so it begins!
We put the chairs back tonight and I had my Thatchers!!!!
Deb now tells me she wants some form of wind break on the side, initially thought trellis but going to see what’s available ready made before I commit !!!!!
Any advice on oiling the wood? Someone recommended Osmo uv oil?
- F35D84F5-8662-4979-A8F7-7A1F9B383B01.jpeg (164.98 KiB) Viewed 539 times
- 8634C7AF-FBFA-4B05-BC89-CF156A1DC480.jpeg (189.53 KiB) Viewed 539 times
- 6A2B586E-A788-499F-BFEC-AD2F65C0E826.jpeg (247.53 KiB) Viewed 539 times
- 1F710CFA-FC65-421C-8649-A9B58B8549B2.jpeg (228.81 KiB) Viewed 539 times
- 568079FF-82B8-4365-949F-8905BFE9C613.jpeg (200.14 KiB) Viewed 539 times
- F5D0FB22-338E-4767-9128-2BD659B73817.jpeg (201.56 KiB) Viewed 539 times
- 57474113-3B9D-4C19-A4AA-F8E9B1444893.jpeg (156.25 KiB) Viewed 539 times
2011 E89 sDrive20i
Online
Pergola build
Danish oil all day long. Osmo is ferking expensive and a bit OTT for outside IMO. Like the close up of the cider; makes me thirsty. If it had condensation running down it I would have driven the 300 miles to christen the pergolaihadablackdog wrote: ↑Tue Jun 15, 2021 8:18 pm Any advice on oiling the wood? Someone recommended Osmo uv oil?
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
Pergola build
It had been in the fridge overnight but I must admit, it didn’t seem really chilled.
Going to look into the oils….which danish oil, or doesn’t brand matter?
2011 E89 sDrive20i
Online
Pergola build
Danish oil is danish oil TBHihadablackdog wrote: ↑Wed Jun 16, 2021 8:35 am Going to look into the oils….which danish oil, or doesn’t brand matter?
https://www.screwfix.com/p/no-nonsense- ... 1ltr/2043r. Good price this one.
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
OnlineNictrix
Pergola build
Went from a coffee table to a fully fitted kitchen with no woodworking experience.
Who wrote this then, do you have a twin?
Online
Pergola build
I have been renovating houses as a hobby since 1996. The woodworking hobby started in about 2011. I made a coffee table as a trial run, then built the kitchen. Then moved (again) and built the house. Then moved again.
I have never said I am a builder or carpenter, because I'm not, I'm a refrigeration engineer. I do, however, have 25 years experience with renovating houses and all that comes with that. I also am not a liar!
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
OnlineNictrix
Pergola build
Calm down dear nobody called you a liar.Pondrew wrote: ↑Wed Jun 16, 2021 6:10 pmI have been renovating houses as a hobby since 1996. The woodworking hobby started in about 2011. I made a coffee table as a trial run, then built the kitchen. Then moved (again) and built the house. Then moved again.
I just found it funny that you said you started with a coffee table but had said you had 25 years of building carpentry experience
