Frost do an internal tank strip fluid Ronk for £13, might be worth a shot before going new tank route.
Old Petrol and engine problem
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- ronk
I will pass that onto him
Lidl did an endiscope a while ago but I couldn’t think of a use - i can now!
- Owdgit
I'm not a gynecologist but I'll have a damn good look
I like to think I'm an optimist.
2010 Grey Z4 E89 N52 3.0 with stuff
2018 VW Arteon 2.0tsi daily workhorse
2020 KTM 1290 Superduke GT
- Crazy Harry
Clean the valve and reassemble the engine then try with a small plastic bottle / lawn mover type tank fed direct to the carbs with new fuel - if it runs fine then spend some money on new fuel lines; filter and a new tank!
- ronk
I think that’s the only way - do it properly but do it once!Crazy Harry wrote: ↑Sat Feb 13, 2021 12:08 pm Clean the valve and reassemble the engine then try with a small plastic bottle / lawn mover type tank fed direct to the carbs with new fuel - if it runs fine then spend some money on new fuel lines; filter and a new tank!
It has to be something lurking in the tank - I still suspect sabotage at sometime. Until it is determined exactly what it is there will always be a nook or cranny with some remaining.
What I said
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Crazy Harry
- ronk
I suppose the gunk in the tank will just have remain a mystery?
Your advice removed the pump from the equation, which was a better route to takeCrazy Harry wrote: ↑Sun Feb 14, 2021 8:15 amSo it was - my bad I must get my brain in gear before reading or follow the words with a finger
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
