Cut in tyre
- flimper
Cut in tyre
Does this need to be replaced? Bloody things brand new as well
- IMG_20190207_141839.jpg (154.05 KiB) Viewed 556 times
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
- BeeEmm
Cut in tyre
Most certainly needs replacing.
I used to have two boys and a girl. Now I have two Men and a Woman.
- road warrior
Cut in tyre
Would fail an not, could blow suddenly, having said that I used mine as a spare and replaced it years later and it was still OK.
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
Cut in tyre
If it's not deep enough to show the ply/cords, then there is no need to repair/replace - and that's exactly what some of the 'rim protectors' on tyres are for. But get it checked out.
Don't be tempted to glue it - as the MOT tester will want to check that it isn't down to the ply/cords. If they can't then they may fail it due to not being able to check.
Continental website wrote:Important to note is that the inside of a tyre contains ply and cords which can become exposed if the tyre has a deep cut in the tread or sidewall.
According to UK road law, if a tyre cut is 25mm or 10% of section width – whichever is greater – then these are grounds for instant MOT (Ministry of Transport) test failure. A cut of this size is considered deep enough to reach the ply and cords.
If you discover a cut on the tyre surface before your MOT test, either on the sidewall or the tread, then it's advisable to replace it with a new tyre. An attempt to have it repaired is not recommended, and for the sake of tyre safety it mustn't be ignored.
- flimper
Cut in tyre
Just taken it down to Halfords to replace tyre before the MOT this afternoon, he said it doesn't need replacing thankfully
- mr wilks
Cut in tyre
Looks like a nick to the rim protector part of the tyre , probably looks way worse than it actually is there in the pic .
Pull it some more , take a look , id even consider supergluing it back just to prevent it possible getting any worse .
As for the rim better call Lynchy
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- flimper
Cut in tyre
I'm not quite so precious about the rims on the mini
OnlineMr Tidy
Cut in tyre
Phew, lucky it was the Mini.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Cut in tyre
The rim protector is thicker rubber so I would glue it back down. What numpty hit the kerb though
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
