Anyone interested in an iDrive Arduino project I'm working on?
- IAmOrion
As per title, anyone interested in an iDrive Arduino project I'm working on? (By interested, I mean, has an interest in it, would like to share info or learn - not a sales pitch to sell anything lol) Long story short, I'm thinking of different things I can have in my Z4, or potentially other vehicle. I started the project more out of curiosity but am now thinking how I could incorporate it into my E85. Although at the same time, I may not use it in the Z because no idea where it would go (Plus I'd need to design and 3D Print a frame/surround for it)
Anyways, currently I have it working as Bluetooth HID module, by combining an Adafruit Feather Bluefruit 32u4, and a custom Can-Bus shield
The can-bus shield uses a TJA1055 SOIC (currently on a SOIC 14 to 2.54mm Adapter) and an MCP2515 I/P
I still have some work left to do on it - the iDrive that only goes left/right (Only has 5 buttons) works PERFECTLY.
The other 2 I'm still working on... they *almost* work perfectly. The non-touch one doesn't recognise rotation yet but everything else works. I do however have my suspicions atm that something is broken and that's why the rotary isn't working.
The touch controller also *almost* works perfectly. All buttons and joystick movements work. I haven't decoded touch can ids etc yet, and also rotary doesn't work - but some inits changed I think...I'm still looking into it.
5 button version uses 100KBPS Can
The other 2 use 500KBPS
There's no section really for this kind of projects on this forum (although it's pretty niche I guess)
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
I have no idea what your on about, but it's great that we have people like you on the forum who tinker with bits and bobs. Good on you and I hope it works out...what ever it is that your trying to do
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- IAmOrion
haha, thanks
I'll make a little video at some point so it makes sense. But basically, it's using an iDrive controller as seen on the pic, as a bluetooth keyboard / mouse for Android/iPhone etc etc
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
Nah, still none the wiser
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I’m with you Fred, he may as well write in Japanese.....
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- IAmOrion
Video finally uploaded
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
Hi, I am working on s similar project with the same idrive knob unit,
I have all accept the rotary working , would you mind sharing the code you wrote that you used?
Much thanks in advance
- IAmOrion
You need to send a 0x273 command to Init the rotary. It should respond with 0x277
What are you using with yours? What’s your hardware setup out of curiosity?
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
I am interested - just starting a project on BMW communications and came over your tread while googling for shields using the 1055 or 1054 chips since there are too many pins to close to each other to solder by hand .... I need to improve my KCAN reading capability as I am just playing on the PT-CAN and FCAN at this time.....
I have a question ... who - module - sends 0x273? and as a result of what preceding action?
And, is there anything I can help with ?
- IAmOrion
Help with.... no, I've completed my project now I made my own CANBus shield for the Adafruit Feather M0 BLE
The TJA1050 is no good as you need the circuit to be fault tolerant, and like you say the TJA1054/1055 are TSOP only, but you can actually do what you need with MCP2515 and MCP2551. You can see from my PCB that I designed it to use THT (Through Hole) instead of SMD mainly because it's so much easier to solder and there was enough room to do so anyways.
My reference regarding 0x273 is for the can controller to send that CAN ID to the iDrive unit to initialise the rotary. The unit will respond with 0x277
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
Thanks - interesting... One only makes a PCB when one has is a product on the go so hopefully you are on a good path
MPC2551 only does ISO 11898-2 High Speed ... that's PT and F-CAN in the E89 series cars. I am after the K-CAN and that's ISO 11898-3 Low Speed. Dominant and Recessive voltages don't quite align between the standards....slowly I am getting there ! Today at least I was able to find some of those ARIES TSOP to DIP adapters like you used.
Does anyone have a clue what's going on?
- IAmOrion
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- ronk
This is black magic / voodoo to me!
Clever stuff
Clever stuff
- shawna
So can we now buy it, rip out the sh***y screen and install a proper LED screen with full control?
