The above! We have got the pro's in for a few nests (around £50 - 10 minute job done). Bit of spray, then they hack the top of the nest which falls into a bag on an extended pole. sorted, the blighters never return to the same spotWondermike wrote: ↑Sun Jul 08, 2018 2:57 pm I believe that wasps don’t return to the same nest the following year, so you could wait until they die off in winter and then remove it yourself. If you want to do it now, I would definitely get a professional in.
Wasps nest
- rosskins
Wasps nest
Current: F-Type AWD V6 & M135i
Before: ZR3.0si, 525d, 325ti, 120d, A3-2.0DSG, 323T4x4, MX3-V6, 2CV, MetroVP, Mini850
Zed was fitted with: None run flats, Stubby, Cruise, Intravee, DrilledFogs, WiredCam & 326s
- TitanTim
Wasps nest
I like this chaps no nonsense approach and he only got stung a few times
https://www.youtube.com/watch?v=6nBaQhH6scw
Surely though he would have noticed the nest before it got as large as it did.
Tim.
Tim.
- Diamond Gaz
Wasps nest
Can't help the OP with any practical advice, but have a read of this wasp removal thread...
https://www.scoobynet.com/344216-wasps- ... eek-3.html
3.0si 06 Montego Blue Roadster
Wasps nest
Stop fannying about Tim - all you need is a bloody great stick - I had a pretty sizable wasp nest in the garden - got said stick and gave it an almighty clout then ran like fcuk up to the house and locked myself in -surprising how fast a 69 year old can run when he has to
- TitanTim
Wasps nest
Diamond Gaz wrote: ↑Mon Jul 09, 2018 6:37 am Can't help the OP with any practical advice, but have a read of this wasp removal thread...
Tim.
- TitanTim
Wasps nest
Hang on, this is potentially a life and death situation in a confined space not in the middle of a cricket pitchgov wrote: ↑Mon Jul 09, 2018 7:50 am Stop fannying about Tim - all you need is a bloody great stick - I had a pretty sizable wasp nest in the garden - got said stick and gave it an almighty clout then ran like fcuk up to the house and locked myself in -surprising how fast a 69 year old can run when he has to
Tim.
- Jembo
Wasps nest
They started to build one under the gutter outside a few years back - shut all the windows, got my son’s high powered water pistol, full pressure blast & slammed window shut.
They were well pissed off outside, made a cuppa & by the time I came back they’d buzzed off.
Wicked they may be, though remember they’re nature’s police, going after all the nasty ticks, lice & other insects that can do us harm... I quite like them, though NIMBY
Lifer 54
Lifer 54
- TitanTim
Wasps nest
I don't dislike them as such as wasps are important part of the insect chain, if they were at the bottom of the garden it wouldn't fuss me, just being in the garage it's a little too close for comfort and multiple stings wouldn't be pleasantJembo wrote: ↑Mon Jul 09, 2018 8:27 am They started to build one under the gutter outside a few years back - shut all the windows, got my son’s high powered water pistol, full pressure blast & slammed window shut.
Tim.
- PerryGunn
Wasps nest
Now if you had a nest like this in the garage...
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
- TitanTim
Wasps nest
Mines larger than that
I read the largest wasps nest ever found was something like 21 feet wide, thats larger than my garage
Tim.
Wasps nest
Just got rid of 3 nests in our loft, 1 was 12" across. Rentokil wasp killer powder does the job quickly and can be blasted up to 8ft away from you.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Pastry
Wasps nest
Does it work on woodworm too Fredrick?
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Now gone:
Wasps nest
Yes
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Wasps nest
Just leave them alone and they wont bother you. They will die off in the winter.
Wasps nest
When they are getting into the house, they need to be got rid of unfortunately. I know they do good things, but they can be nasty neighbours too.
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
