Grafting
- Pastry
Grafting
Grafting Rob?.... you’ve left it a bit late in life to start doing that
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Now gone:
Grafting
They nicknamed him ‘Blister’ Pastry......as he used to show up after the work was done.....
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Nanu
Grafting
As long as you extended an existing lease and not purchased a new 100 year one ?Smartbear wrote: ↑Wed Jun 06, 2018 7:13 pmI extended the lease on my flat but needed to buy out the leaseholder with a collective enfranchisement, once that happened it’s pretty cheap to extend the lease to a thousand years so it’s never an issue againfirebobby wrote: ↑Wed Jun 06, 2018 7:09 pmHow long has the lease got to run ?? surprised the solicitors aren't to bothered about not seeing the leaseSilverzedtom wrote: ↑Wed Jun 06, 2018 6:52 pm
It looks like its slowly coming together. The solicitors asked me if it would be ok to continue without a copy of the leasehold as apparently it couldn’t be found anywhere (I’m buying a flat). Then I noticed the annual maintanence charge went up 70% from listed in the contract. They’ve needed a few nudges along the way just to move things forward too
Hopefully yours is goes smoothly
A friend of mine has just done that with a company called Simarc and the ground rent went up to £350 pa which wasn't the issue. It was the small print that had the ground rent going up by the retail price index each year that was the problem, effectively doubling it every 10 years. Building Societies won't touch it now. Work it out and see how much your paying after 50 - 60 year and you will see why. It's frightening
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
Grafting
OI.....cheeky chuff.....!! Laugh a minute me......
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Smartbear
Grafting
Yes, it was a small block of 5 flats and each owner became a leaseholder and had a share in the lease-once you’re leaseholders you can set the ground rent to whatever you want & sort out your own maintenance peopleNanu wrote: ↑Wed Jun 06, 2018 7:46 pmAs long as you extended an existing lease and not purchased a new 100 year one ?
e85 3.0si sold
- Smartbear
Grafting
I kept that railway running singlehandedly i’ll have you know
And I have a certificate to prove it Rob
e85 3.0si sold
- Smartbear
- jabber
Grafting
Blimey I did 38 yrs with a well known communication company and all I got was a lift home
Z less again
- Smartbear
Grafting
I worked in comms for a while, I installed the digital exchanges all around the country
e85 3.0si sold
- jabber
Grafting
Spent a few years as C.O.W for that both GPT and Ericsson installations
Z less again
- Smartbear
Grafting
Yep, I worked for both of them installing system X and system Y
e85 3.0si sold
