Repair to pressurised pipe
- obewan
I would appreciate some advice from the knowledgable people on this forum
I help out at a local football team where we have a weedkiller/fertiliser sprayer ' It is towed behind a small mower and powered by it's battery.
Getting it out of the garage I caught the pipe snapping it out of the tee junction
The crack is as per the red line in the photo
The plastic is quite hard (not soft like a nylon waste pipe) so I used a 'super glue' - It went back together well and I thought it was fixed
However when connecting back up and pressurised, there is air/fluid bubbling out of the crack.
Could anyone give me some ideas please on the best method to repair fully
I was wondering about a gauze wrapped in a figure of eight around the tee junction and fibre glass
Or is there a better way?
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
Honda CB500F.
its solvent welded together, to fix properly you would need some pipe and a tee and straight then chop it out and replace.
2004 E85 Z4 2.5i SE Sterling Grey.
- Nictrix
Could it be melted with a soldering iron?
obewan wrote: ↑Sun Apr 01, 2018 7:14 pm I would appreciate some advice from the knowledgable people on this forum
Try some Qbond, it’s amazing stuff. Glue it together, takes 7 seconds and then poor some of the powder you get with it over the crack and then drop a few drops of glue on it. It will be hard as nails.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- obewan
Thanks for the ideas guys - I wondered about the soldering iron - just thought being a 'hard' plastic it may not melt well
No harm in trying first I guess
Re renewing the tee piece - Not sure how I would go on with the main coupling at the top. I'll have to see how it is fixed in
Would the Qbond stuff work without breaking the joint again?
Honda CB500F.
Honda CB500F.
Pipe solvent cement will melt the plastic and seal the crack, just make sure the crack and pipe are dry before hand
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ducklakeview
Good tip Fred, I’ll remember that...
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- obewan
Quick update
I took the plunge and had a go with a soldering iron - seemed to work a treat
I'll couple it up later in the week (if it ever stops raining!) and see if it has worked
If not I now have a small recess so will try the pipe solvent as suggested
Many thanks for the suggestions
Honda CB500F.
Honda CB500F.
