Got this today
bluespit
Got this today
Post by bluespit » Fri Mar 09, 2018 9:43 pm
cracking toy
:D
now I'm about to have more time I've suddenly got less toys to play with!
Ducklakeview
Got this today
Post by Ducklakeview » Fri Mar 09, 2018 9:51 pm
Great aren't they - Mine gets used a LOT! :D
Ours could be twins :)
Mike
Silverzedtom
Got this today
Post by Silverzedtom » Fri Mar 09, 2018 10:05 pm
Would love one of these. Must make everything so much easier and save huge amounts of time.
If only I had a garage to put one in :(
E85 2.5si
F55 Cooper S
patriot66
Got this today
Post by patriot66 » Sat Mar 10, 2018 1:53 pm
I SO want one of these ! Would make life so much easier. :thumbsup:
PerryGunn
Got this today
Post by PerryGunn » Sat Mar 10, 2018 2:08 pm
bluespit wrote: Fri Mar 09, 2018 9:43 pm cracking toy
Which model did you get?
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
bluespit
Got this today
Post by bluespit » Sat Mar 10, 2018 2:29 pm
this...
https://www.ebay.co.uk/itm/Eurotek-MRS3 ... SwnHZYkHFd
never been able to embed ebay links.
bought from a 'clearance' sale - hardly used
Crazy Harry
Got this today
Post by Crazy Harry » Sat Mar 10, 2018 2:34 pm
Short vid of mine I made for DLV when we were thinking/getting round to buying them
https://youtu.be/BvtB0mMhGD0
Then movement of the car isn't the ramp - you can't apply the handbrake with a harness on so its always parked in gear the movement is just freeplay in the gearbox and diff. Wouldn't be without the ramp now - so much easier than bending down or lying on the floor.
NickDE
Got this today
Post by NickDE » Sat Mar 10, 2018 2:46 pm
Ducklakeview wrote: Fri Mar 09, 2018 9:51 pm Great aren't they - Mine gets used a LOT! :D
I've got an E46 just like that ! Vanos is running well now.
Darkness gone, go Darknes2, go Frozen, go Tronic
Ducklakeview
Got this today
Post by Ducklakeview » Sat Mar 10, 2018 2:54 pm
NickDE wrote: Sat Mar 10, 2018 2:46 pm
:D
Mike
Truth
Got this today
Post by Truth » Sat Mar 10, 2018 8:52 pm
Looks like the new garage build will be getting an addition!
Z4MC
Crazy Harry
Got this today
Post by Crazy Harry » Sat Mar 10, 2018 9:48 pm
Truth wrote: Sat Mar 10, 2018 8:52 pm Looks like the new garage build will be getting an addition!
If you get the type DLV and I have think about laying the floor with a hollow to accommodate the lift - it will make getting sports cars over it easier. If you get the 'drive over' type like Bluespit its easier to get sports cars over but you have the ramps constantly under the car which can make access harder to some parts. I made some long ramps to get my Caterham; Zed and my lads MR2 onto mine. Its just needs thinking about how you would use it; which is the most appropriate type and then planning building work around it.
Online
buzyg
Got this today
Post by buzyg » Sat Mar 10, 2018 10:30 pm
Now that's a proper toy. :thumbsup:
Beedub
Got this today
Post by Beedub » Sat Mar 10, 2018 11:36 pm
bluespit nice!! but not liking the clearance on the underside at all.......
bluespit
Got this today
Post by bluespit » Sat Mar 10, 2018 11:45 pm
this is my third go at getting a mid rise lifter, the first one was a really clumsy affair a bit like this one.
http://www.automotechservices.co.uk/products/as-5500-2-5-tonne-scissor-lift/
worked well but was a pig to set up and totally in the way when the car was off it, that sounds a bit daft but it has so many sticky out bits I was always tripping over it.
the second was a manual mini lift like this one which is great as long as you and space at the side to slide the lift under the car.
https://www.cjautos.eu/MINI_TILTING_CAR_LIFT_p/cl03.htm
I've still got this but unless my pal wants it I'll bung it on ebay soon
my one piece of advice would be to get a lift which has no cross pieces so access is as clear as possible
bluespit
Got this today
Post by bluespit » Sat Mar 10, 2018 11:47 pm
Beedub wrote: Sat Mar 10, 2018 11:36 pm bluespit nice!! but not liking the clearance on the underside at all.......
ahh, there is about an inch between the top of the lifter and the jacking blocks under the Z. so clearance is fine. It'll more likely be used for my classics which have much more clearance anyway
