Tire pressures
Tire pressures
Any one know what the pressures should be on the 2.0l z4 with 18 inch rft on it, handlings not great so thik will check th pressures
Z4 2.0i with M sport package inc 18 inch wheels seats and stirring wheel! Stubby, chrome exhaust trim
- ranski
Tire pressures
30 / 32 or 32 / 35 is quite common
Z4 3.0 / Mods done... too many to mention
- Adamski
Tire pressures
I run 32F 36R. I'm on non RFTs though. Dropping the pressure a little may help with RFTs
Gone: Z4M Coupé|Black Sapphire|OEM CSLs|Aero Skirts|OEM Strut Brace|Nav|Heated Seats|Logic 7 Pro Hi-fi|Bluetooth|Carbon Leather|PDC|BMW Assist|Stubby
Gone: Cherished 2003 3.0i Black Sapphire Roadster
- bat1959
Re: Tire pressures
Owners handbook or next to the drivers door lock. All the info you need.
2004 3.0i SE, My MOD's: Gaptech remote/one touch, MFSW, Cruise, brake light ring mod, OEM strut brace (black), OEM MP3 capable head unit & Stubby.
Re: Tire pressures
So I pumped the tires up to 30/ 32 as suggested, the were 33 at the rear and front right 27 left 28 made a huge difference to the handling, would have thought when I bought the car dealers would have checked this as only bought it 3 months ago
- ranski
Re: Tire pressures
- Bing
Re: Tire pressures
32 front 36 rear sounds correct - but the label on the driver door shut next to the lock will tell you as pinted out. THB, if you haven't put air in the tyres for three months then they were probably right when you got it, the air has just slowly leaked. I drive mine every day, and try to remember to check them once a week - I'd suggest every couple of weeks as a minimum would be best, if only because if you don't you'll go through tyres at a rate of knots, and your fuel consumption will drop
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- Finisterre
Re: Tire pressures
I tend to have the tyre pressure the same front and back. 32psi
I have heard that BMW have slightly higher rear tyre pressure to encourage oversteer but I am uncertain what the benefits is. (Unless it is safer to go through hedges backwards!) Does anyone know if this is why they have decided a 50:50 weight distribution car should have a smaller contact patch at the rear?
E85 2.0. + E39 530i touring.
- sars
Re: Tire pressures
As the car accelerates the weight distribution changes to the rear, so the rears have a higher pressure to compensateFinisterre wrote:I tend to have the tyre pressure the same front and back. 32psi
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
- Herminator
Re: Tire pressures
BMW and all manufacturers will tend to keep things on the side of understeer, it's much better to go through the hedge pointing forwards
I believe the higher pressure on the rear is partly because they're wider, there's more "unsupported" tyre tread.
BMW M4CS, San Marino Blue, CCBs
Gone but not forgotten- Z4M Roadster, E31 840 Ci Sport, E85 Z4 3.0 Sport.
- Adamski
Tire pressures
I thought the higher pressures were due to it being RWD?
- Bing
Re: Tire pressures
In every car I have ever driven, the drive wheels are higher PSI than the non-drive wheels - irrespective of whether it's FWD or RWD, and the Z4 is the first car that I have had that has a staggered set-up. My car says 2.3 bar on the front, 2.6 bar on the back, which works out at 33 / 38 psi I think. I was surprised the rears are so high, but there's lots of power, the weight shifts as Sars says, and perhaps the wider rears also have something to do with it.
However, IMHO you should look at the door shut plaque showing the pressures and do what it says, because someone brainier than me has worked it out already. If you then want to adjust the pressures that's your preference - i've just never bothered playing around. As my winters are all the same size I've dropped the back by 2 psi to 36, but that's only for fear of them exploding. Irrational, I know, but it's my head and I have to live with it
EDIT - Just realised that my iPad auto-wrong function made me look like I had a fit toward the end of the first sentence in the second para. For amusement, used to say "becausthose one somewhermob rainier than me has worked it out for me."
- sars
Re: Tire pressures
I have 225/45/17's all round and the tyre pressures are different 2.4 Bar front and 2.9 Bar rear so I don't believe that to be the reason, also when you break you want the fronts to deform and get flatter to increase surface contact, this may be another reason for the differenceHerminator wrote:I believe the higher pressure on the rear is partly because they're wider, there's more "unsupported" tyre tread.
- Ewazix
Re: Tire pressures
I've played around with the pressures on my non-RFTs and settled on 32F/34R, much lower makes it feel 'baggy' on the turn in, much more starts to make it unsettled on bumpy bends.
Tyres generally lose a minimum of 1 ft/lb per month, and need seasonal adjustment to take account of ambient temperatures. You lose/gain roughly 1ft/lb of pressure for every 10 deg F so they will be a few pounds down in cold weather and need a top-up.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- RCT_Z4Coupe
Re: Tire pressures
Is that on 18's? I was disappointed in the handling and ride of my car when I had my RFTs on the manufacturer recommended pressures (33/39). I lowered to 32/35 which really made the car feel settled with less dramatic tramlining. Made a significant difference.Ewazix wrote:I've played around with the pressures on my non-RFTs and settled on 32F/34R, much lower makes it feel 'baggy' on the turn in, much more starts to make it unsettled on bumpy bends.
Z4 3.0 Si Sport Coupe Navy Nappa Leather, Heated Memory Seats, Xenons, Navigation System + Bluetooth, Park Assist, Cup Holders
