Offset on e89
Alloy wheels and tyre discussion
Panta Rhei
Offset on e89
Post by Panta Rhei » Sat Jun 12, 2021 10:23 am
Gentlemen,
car: e89 lowered
rear wheels: 9,5x18 ET 33 (agressive, I prefer them) or 9,5x18 ET 45 (safe?) 265/35 tyre option. 9,5x19 ET 35 is a standard on zroadster as I read: https://www.zroadster.com/forum/threads ... 742/page-1
For reference, here is a pic of 10x19 ET 40, which is 0,6 mm less towards wheel arch than 9,5 ET 33. It seems to me that there won't be any rubbing. Looks pretty safe.
on the other hand, here is 9x19 ET 44, which is 17,4 mm less than 9,5 ET 33. Idk about the looks, seems pretty hid to me.
Pbondar
Offset on e89
Post by Pbondar » Sat Jun 12, 2021 11:21 am
On 18” 8J and 8.5J were the widest OE rims on 19” 8J and 9J were the widest runs fitted all at 29/40mm
I run 8.5J 235/40 18 and 9.5J 265/35 18 with 30/40 offsets on MSport springs
With 35 rear offset I just got rubbing on the RH outer wheel arch liner on very big bumps at very high speed
Panta Rhei
Offset on e89
Post by Panta Rhei » Sat Jun 12, 2021 12:29 pm
Can you tell me your tyre brand as far as I know they may differ in width even when we are comparing same sizes...
Pbondar
Offset on e89
Post by Pbondar » Sat Jun 12, 2021 12:33 pm
Panta Rhei wrote: Sat Jun 12, 2021 12:29 pm Can you tell me your tyre brand as far as I know they may differ in width even when we are comparing same sizes...
Goodyear Asy 5
The other issue is mine has fresh M3 version bushes / steering parts so the geometry is spot on..older bushes etc may cause the wheels to ‘topple inwards’ a bit..
Also I have B8 Bilstein dampers which would improve the bump performance..
Panta Rhei
Offset on e89
Post by Panta Rhei » Sat Jun 12, 2021 12:50 pm
Ok, thank you. Look at this guys M3/M4 wheels. They are 10x19 ET 40 265/30.
Mine would sit nearly the same, 0,6 mm difference. They look like they fit maybe because of the 265/30 tyre on a 10 rim - streched a bit.
Pbondar
Offset on e89
Post by Pbondar » Sat Jun 12, 2021 1:21 pm
Panta Rhei wrote: Sat Jun 12, 2021 12:50 pm Ok, thank you. Look at this guys M3/M4 wheels. They are 10x19 ET 40 265/30.
I know people who have done the M3/M4 wheels on 245 and 276 and no issues..maybe I just drive faster over bigger bumps.. :driving: :thumbsup:
Panta Rhei
Offset on e89
Post by Panta Rhei » Sat Jun 12, 2021 2:21 pm
I lean towards 9,5 ET 45 now, because I can always put 5 or 10 mm spacers.
If I buy 9,5 ET 33 I am done and probably screwed if rubbing occurs.
Pbondar
Offset on e89
Post by Pbondar » Sat Jun 12, 2021 3:04 pm
Panta Rhei wrote: Sat Jun 12, 2021 2:21 pm I lean towards 9,5 ET 45 now, because I can always put 5 or 10 mm spacers.
Wise move! IMHO :thumbsup:
