Just had my 108s refurbished after stripping them down. I now have the task of re-assembly. The question I have is should I use loctite on the threads or not? I can't help but think it is just a matter of time before they go again and given all the posts regarding seized and sheared bolts I have read, I fear that loctiting them is just asking for trouble should I ever need to strip them again. My preference would be not to, but I notice some others have said they did.
I would be interested in your thoughts.
108s to loctite or not to loctite on re-assembly
- Magicarcher
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- mr.tourette
just use the blue semi permanent type rather than permanent
- mr wilks
I wouldn't & never have done , once you out them back together at what you think are tight leave alone 24hrs , then try them all again & i'd be amazed if you don't get a extra half turn on at least half .
I suppose you could glue them & the extra turn would "break" the bond ?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- abar121
This. Works great and is perfect for that use.mr.tourette wrote: ↑Wed Apr 28, 2021 8:50 pm just use the blue semi permanent type rather than permanent
'07 Z4M Interlagos Blue. All options except extended leather.
- enuff_zed
I'd follow this experience.mr wilks wrote: ↑Wed Apr 28, 2021 9:09 pm I wouldn't & never have done , once you out them back together at what you think are tight leave alone 24hrs , then try them all again & i'd be amazed if you don't get a extra half turn on at least half .
If you get an extra movement on them once they've 'rested' then you will break the seal and it will have been a pointless exercise.
