Bored of CSL’s....any idea’s...?
- Panta Rhei
Okay so I have 225/40 R18 ET 37 fronts (Eibachs fitted) and I just checked my car in the garage.
There is NO way you can safely push that out 10 mm without rubbing occur. I cannot see that. I am even amazed that I DO NOT have any rubbing on corners, because it looks like it should rub.
Please just show me your tyre in the wheel arch area behind the side bumpler reflector light
Are you sure about your spec? Like 100% sure about the offsets? Tyres? Negative camber?
If you have 8.5 ET 34 that means you are 9,3 mm further away. HOW?!
Your spec vs mine:
Your spec vs mine:
- BMWZ4MC
It looks like you have much less negative camber that StigJ.Panta Rhei wrote: ↑Fri Oct 09, 2020 9:00 pm Okay so I have 225/40 R18 ET 37 fronts (Eibachs fitted) and I just checked my car in the garage.
Your spec vs mine:
Have you an en face photograph of your car to compare with this?
S2000 GT - gone
- Panta Rhei
Am gonna deliver today BMWZ4MC
Yes my wheel arch are eaten up because first I had 235/35 Michelin PSS with no negative camber. I have OEM guide supports, but I have pulled the guide pin. So I get a little more negative camber.Panta Rhei wrote: ↑Fri Oct 09, 2020 9:00 pm Okay so I have 225/40 R18 ET 37 fronts (Eibachs fitted) and I just checked my car in the garage.
Your spec vs mine:
I have had these wheels since 2011. This is the original spec and were I bought them: http://www.wheeldude.com/catalog/produc ... ts_id=6410
After I got them, all wheels have been machined 4mm to get a higher offset and better fitment for my E86 since they are meant for E9x.
Also my H&Rs are lowering 5mm more than the Eibachs. So they would push the top of the wheels further in.
One last thing, You have 8" with 225 and less stretch on the tire wall.
Hellrot '06 BMW Z4 Coupe 3.0si
Instagram: @StigJ77 & @bmwe86driver
- Panta Rhei
Yes, that is something worth to consider. I forgot bout thatOne last thing, You have 8" with 225 and less stretch on the tire wall.
- Panta Rhei
I want to add something.
This is a photo of @ga41 member who owns Z4 M and has got 12,5 mm spacers on front. He says:
I drive 3.0si roadster with 8.0 ET 37 fronts with 225/40 R18 tyre plus Michelins pilot sports and I have the same issue. The part with red circle is where the tyre scrapes fender. I am on eibachs. This means, and I would never guess, that even 10 mm spacers are too much when you have got eibachs fitted. 5 mm is absolute max.Here's what that pointy edge did to my admittedly wider than normal AD08's after the spacers.
Perhaps you guys can help. I have space grey z4 coupe si and stuck between these 2 similar design rims. A 7 spoke csl type (similar to vmr 710) and a genuine 8 spoke csl type. I keep going back and forth with some people having their pictures show it off better than others. I attached what I thought showed the best comparision.
08 Space Grey Z4 3.0si Coupe
96 Cosmos 318ti (Cali Top) 98 Avus 323i v
Prev. (no order)
99 Silver M3 v 96 Hellrot Z3 1.9
95 Cosmos M3 C 98 Green 323i v
99 Grey 328i v 06 M3 C
98 Grey 325i v 04 325i 275,000 mi.
05 ZHP C (flew off freeway) 05 ZHP C
Prev. (no order)
Actually these seem a little more fair as they have aero skirts. Bottom is running avante garde m359
Prev. (no order)
Prev. (no order)
Are these Rota GTR's on the blue coupe?
[/quote]
[/quote]
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
