Everybody says 19" are uncomfortable
It’s all relative I guess, the numpty who had mine before me put runflats on the 224s when I changed to CSLs on non runflats And changed to eibachs at the same time, the ride improved.
Standard 224 sizes and standard CSL sizes.
It runs about as hard as my R56 JCW
Z4MC
- Bufort
Run flats are the worst tyres ever though.Truth wrote: ↑Wed Feb 19, 2020 9:39 pm It’s all relative I guess, the numpty who had mine before me put runflats on the 224s when I changed to CSLs on non runflats And changed to eibachs at the same time, the ride improved.
OnlineMr Tidy
Those are exactly the sizes and offsets I have on mine, but I couldn't find a brand name on them.
Do you know what brand yours are? I'm assuming they are probably the same.
Thanks.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- MrPT
BBS. They're not reps.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
OnlineMr Tidy
Nice - I'm assuming BBS stamp them somewhere? Mine did come with BBS centre caps (that I have changed)!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- MrPT
Yep. "BMW" on the front of the hub, inside the M badge, and "BBS" on the back of the spokes.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- z4pilot
On a non M/// the main risk of rubbing is at the front. If you go much wider than 15mm greater offset than the standard 8j wheel, you run the risk of rubbing over sharp compressions, especially if lowered or your suspension is tired. You can reduce the risk by playing around with the tyre width - drop down to a 215 section tyre for instance. If you go with an 8.5j width wheel you need to adjust the allowable offset for the greater width. At the back, most people aim for a 20mm increase as this more or less gives the best visual improvement, although you can get away with wider, especially if you run extra camber to tuck the wheels in a little at the top. Again, this is an absolute measurement using the standard wheel sizes as a baseline - adjust as necessary with wider wheels and offsets to give the same overall track increase. Don't forget that when people quote M/// numbers at you that they won't automatically work on a non M/// - they have different axles and so their starting offsets are different - the offsets needed to bring M/// wheels flush will be too extreme for a non M.Bufort wrote: ↑Wed Feb 19, 2020 8:45 pmYeh I use that all the time - but it doesn't tell me what I was actually trying to find out with this post - whether it will fit your arches or if it'll rub.z4pilot wrote: ↑Wed Feb 19, 2020 8:34 pm If you use willtheyfit.com you can have a play around with the various widths and profiles to see what the impact on diameter will be. Handily it also tells you what the impact on your speedo will be - too extreme an increase in diameter will throw your speedo out by a few miles per hour.
Now Gone - 2008 Coupe, Montego Blue, Champagne leather and Piano Black interior, Eibachs & Koni Sport shocks, Style 230 19s, Eisenmann Quad - approaching perfection...
- MrPT
^ good advice. It’s definitely worth having a play with a tyre fitment calculator so you know where you’ll end up visually compared to your current setup.
I went with 12mm front and 15mm rear spacers with my non-M roadster, which had the common wheel sizes of 18 x 8J ET47 and 18 x 8.5J ET50. As z4pilot says, +15mm and +20mm vs stock is probably the most popular, but can look a little rollerskatey if you don’t also lower the car.
OP - as above, the CSL sizes Mr Tidy and I have been talking about won’t be suitable for a non-M. The below are very popular reps (for example) with offsets that work well on a non-M. With 225/35/19 front and 255/35/19 rears they should also be quite comfortable.
https://www.bmautosport.co.uk/showroom/ ... rear-p-422
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Bufort
I'm not planning on trying to get it to stick out more; I'll just use whatever it takes to make a 19" wheel with a comfortable tyre fit under my arches with no rubbing at all.MrPT wrote: ↑Thu Feb 20, 2020 9:12 am I went with 12mm front and 15mm rear spacers with my non-M roadster, which had the common wheel sizes of 18 x 8J ET47 and 18 x 8.5J ET50. As z4pilot says, +15mm and +20mm vs stock is probably the most popular, but can look a little rollerskatey if you don’t also lower the car.
Thanks for all the help - and to reiterate the answer for any future viewers of this thread - YES, you can fit 19" wheels with the same profile tyres as 18" wheels for comfort.
- tomscott
I need some new tyres for my CSL this summer and wondering what to go for. The Mich are the obv choice but they are a decent premium over all the others.
Stupid question what's the benefit of reducing the tyre width on the back from 265 to 255? Do you not loose a bit of rubber to the road but also does it not stretch the tyre giving less rim protection?
- mr wilks
Ive just bought a set of Dunlop SportMaxx RT2 for my CSLs , been trialing them out on the 224s for the last month or sotomscott wrote: ↑Thu Feb 20, 2020 7:57 pm I need some new tyres for my CSL this summer and wondering what to go for. The Mich are the obv choice but they are a decent premium over all the others.
Can't fault them & around £400 for the set with 255 35 19 rears , ive always preferred this fitment for the added comfort plus dependent on brand there is no stretch to the sidewall & if you do some study changing from 265 30 19 to 255 35 19 on a 9.5j doesn't mean you lose contact patch of tyre on tarmac . also worth noting this is the size the E46 M3 had on its rear CSLs
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- mr wilks
Its not in question that you can fit the tyres to the wheels , whether they will then work on your car is a totally different matter .
There are many other deciding factors to consider such as wheel width , offset , tyre brand ( & if new with full 8mm tread or partworn )
Suspension set up also needs considering & don't forget you will be upping considerably the rotational mass so the car may well feel different to drive .
Lots to consider
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- tomscott
That’s great value! Almost have the price cheaper of the pilots!mr wilks wrote: ↑Thu Feb 20, 2020 8:09 pmIve just bought a set of Dunlop SportMaxx RT2 for my CSLs , been trialing them out on the 224s for the last month or sotomscott wrote: ↑Thu Feb 20, 2020 7:57 pm I need some new tyres for my CSL this summer and wondering what to go for. The Mich are the obv choice but they are a decent premium over all the others.
From a size point of view the standard 19” M3 and the M3 CS wheels were 255 but the CSL was 265 although they all run 19x9.5
https://bimmertips.com/oem-bmw-e46-m3-w ... ons-specs/
- Bufort
How would that not mean you lose contact patch? If you go from a 265 to a 185, you lose 80mm of the contact patch, if you go to a 255, you don't lose much, 10mm, but you're still losing some. Unless you're saying the actual tread width on a 255 and a 265 are the same size, and its just the overall width that changes (the bulge at the sides), but I don't think thats the case.
The minute bit of 'stretch' that you're getting by fitting a narrower tyre to the same size rim, and the inconsequential amount of the radiused corner that will roll from the side to the top of tyre will be vary between every tyre made and therefore cannot be taken into consideration if you're generalising.
- z4pilot
You're assuming that the contact patch is the full width of the tyre - that's probably not the case, I'm surmising that it will be central to the contact point with the road and it's area will be affected by variables such as tyre width, but also suspension geometry, tyre inflation, tread depth (there's a reason why racing tyres are slick) etc. The 10mm difference between the width of a 255 and 265 section tyre probably doesn't amount to a huge difference in contact patch - and in any case, the opinion has been expressed on here a few times that the non-M Z4 is over-tyred, so in real world condintions, you'll never notice a lack of grip, but will notice an increase in comfort.Bufort wrote: ↑Fri Feb 21, 2020 12:13 pmHow would that not mean you lose contact patch? If you go from a 265 to a 185, you lose 80mm of the contact patch, if you go to a 255, you don't lose much, 10mm, but you're still losing some. Unless you're saying the actual tread width on a 255 and a 265 are the same size, and its just the overall width that changes (the bulge at the sides), but I don't think thats the case.
