Wheel shredded
Wheel shredded
Hi guys, looking for some advice. Apologies if basic question. Recently had a flat left rear and decided to get all new wheels and 2 new rear tyres as nearing the end of their life anyway. When they took the tyre of and showed it to me all the inside was shredded and the inner sidewall almost looked separated from the tyre. They weren't sure exactly why but suggested tracking might need to be done. Just wanted to see if anyone might have any ideas why it happened, plan to get a 4 wheel alignment done this weekend regardless
Faz
Faz
Wheel shredded
Sounds like you drove some distance while it was flat/ low...that’s what they look like internally when you do that..
- buzyg
Wheel shredded
Yup agree completely with this.
Wheel shredded
Were they run flats that you or someone else has run while flat?
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- enuff_zed
Wheel shredded
If the tracking were far enough out to shred the inside of a tyre (if that is even possible), I'm sure you would have felt something.
I'm quite surprised the tyre place suggested it in the first place. Did they not even consider it was caused by running it flat?
- kis
Wheel shredded
I had something similar happen to mine. When I first got the car I didn’t realise quite how “aggressive” the rear camber is. Had tracking looked at and that was fine. The Zed is set up in a way where the inside will wear quicker than the outside, so if you don’t check the tread depth from inside to outside you could be fooled into thinking that just because the outside shows tread still good, the inside is too.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Wheel shredded
To be fair, your outside tread is on/below the wear indicators too - and well below what I'd let road tyres go down to!
- Marlon
Wheel shredded
My rear Kuhmo tyre split traveling home on the outside lane of the motorway. Heard a loud vibrating noise, fortunately the steering stayed sharp - pulled over onto hard-shoulder and the RAC arrived with a flatbed. Had both rears replaced with Bridgestones.
This was nothing to do with tracking, there was plenty of tread and they weren't run-flats. I think its a lesson in not scrimping on the cost of tyres for sports car; the previous owner spared no expense on the car but definitely dropped the ball buying tyres
Gone: 3.0si 2008 E85
911 997 Carrera S
- kis
Wheel shredded
Yeah it was, but back then I was a bit of a noob with car maintenance stuff. Recently purchased and fresh MOT so I was lulled into a false sense of security. It was probably this very tyre that prompted me to delve so deep into tyres and wheels... hence this thread.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
Wheel shredded
Never seen anything like that!Marlon wrote: ↑Sun Nov 17, 2019 8:13 pm My rear Kuhmo tyre split traveling home on the outside lane of the motorway. Heard a loud vibrating noise, fortunately the steering stayed sharp - pulled over onto hard-shoulder and the RAC arrived with a flatbed. Had both rears replaced with Bridgestones.
To be fair Kuhmo's aren't that bad, mid-range. They're similar to Falkens, Avons, Vreds, etc... so pretty surprising. That being said, for the Zed I'd (personally) only get premiums, but thats more for performance. This is like a failure of the tyre itself, something I'd not expect even for budgets! Did the tyre fitter say anything about possible causes?
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Marlon
Wheel shredded
My Indy was surprised - he also said the other rear was showing signs of failing in the same way. He'd not seen anything like it but suggested upgrading to higher rated rubber.kis wrote: ↑Mon Nov 18, 2019 10:32 amNever seen anything like that!Marlon wrote: ↑Sun Nov 17, 2019 8:13 pm My rear Kuhmo tyre split traveling home on the outside lane of the motorway. Heard a loud vibrating noise, fortunately the steering stayed sharp - pulled over onto hard-shoulder and the RAC arrived with a flatbed. Had both rears replaced with Bridgestones.
911 997 Carrera S
- BMWZ4MC
Wheel shredded
Marlon, perhaps you should send photographs to Kumho, especially if there was a reasonable amount of tread life remaining. I’m sure they’d be interested to know it failed suddenly at motorway speeds since there would be grounds for litigation if injury or death had resulted.
S2000 GT - gone
- kis
Wheel shredded
BMWZ4MC wrote: ↑Mon Nov 18, 2019 11:18 am Marlon, perhaps you should send photographs to Kumho, especially if there was a reasonable amount of tread life remaining. I’m sure they’d be interested to know it failed suddenly at motorway speeds since there would be grounds for litigation if injury or death had resulted.
I was thinking the same, its not like it was any fault from you, the driver (hitting a curb, etc). It seems like a construction/manufacturing issue. By the looks of it, there was plenty of tread still present.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
