What size spacers.............
- enuff_zed
......................would I need to perfect the look of my, otherwise standard, Z with these 18" wheels?
Don't want to lower it by the way.
- IMG_0099.JPG (265.9 KiB) Viewed 2282 times
- scootr
Beautiful Zed Enuff
E89 3.0L 6 MT gone
Michelin P4s
Bilstein struts & shocks
Luxon tower brace
Michelin P4s
Luxon tower brace
- mr wilks
For me nothing on the front , the rear i would add 10mm/12mm or 15mm .
It will enhance the stance measurably .
I always ran 9.5 et 35 rears on the 3 E89s i owned , sat & handled a treat plus filled out the arches without rub
To get the same rear fit you would need a 15mm spacer
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- enuff_zed
Ha ha!mr wilks wrote: ↑Wed Oct 16, 2019 7:48 pm For me nothing on the front , the rear i would add 10mm/12mm or 15mm .
I had a little bet with myself that you would be along within the hour. 29 minutes!
So you think the front looks ok. So would be 12 be a safe bet or are you saying 15 is fine with no issues?
I think I will still have a fair vertical clearance as I don't intend to lower it, but cornering hard?
Let's face it, the spacing out is for the look when the thing is parked up really.
- IMG_0100.JPG (234.31 KiB) Viewed 2267 times
- enuff_zed
- mr wilks
That pic above shows the E89 "problem" off perfectly , the rear wheel track looks narrower than the front not a good look imo & as with the ZMs a wider rear stance looks far better which is why i switched all the previous wheelsets off & went for a wider rear track
If you added to the front too you would be chasing your tail so to speak .
Add 12mm or 15mm hubcentric to rear & you should be suited
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- enuff_zed
Agreed.mr wilks wrote: ↑Wed Oct 16, 2019 8:00 pm That pic above shows the E89 "problem" off perfectly , the rear wheel track looks narrower than the front not a good look imo & as with the ZMs a wider rear stance looks far better which is why i switched all the previous wheelsets off & went for a wider rear track
For a while I owned both a 2.8i Capri and a 1.6 Mk2.
Exactly the same issue with the wheels not filling the arches properly on the smaller model.
I like these wheels. Easy to keep clean, good looking (to me), and a relatively comfortable ride, which will improve shortly when I wave bye bye to the RFTs.
So I think then that I will start with a pair of 15mm spacers on the rear. Thank you.
Any recommendations on which to buy?
- mr wilks
Ive used Mtec ones many times https://www.ebay.co.uk/itm/BMW-15MM-MTE ... Swg6Nc~kaG on ebay around £35 with bolts , i wouldn't buy into the snobbery over buying spacers with big brand names , simply not necessaryenuff_zed wrote: ↑Wed Oct 16, 2019 8:04 pmAgreed.mr wilks wrote: ↑Wed Oct 16, 2019 8:00 pm That pic above shows the E89 "problem" off perfectly , the rear wheel track looks narrower than the front not a good look imo & as with the ZMs a wider rear stance looks far better which is why i switched all the previous wheelsets off & went for a wider rear track
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- enuff_zed
Excellent. Thank you for your time tonight.mr wilks wrote: ↑Wed Oct 16, 2019 8:10 pmIve used Mtec ones many times https://www.ebay.co.uk/itm/BMW-15MM-MTE ... Swg6Nc~kaG on ebay around £35 with bolts , i wouldn't buy into the snobbery over buying spacers with big brand names , simply not necessaryenuff_zed wrote: ↑Wed Oct 16, 2019 8:04 pmAgreed.mr wilks wrote: ↑Wed Oct 16, 2019 8:00 pm That pic above shows the E89 "problem" off perfectly , the rear wheel track looks narrower than the front not a good look imo & as with the ZMs a wider rear stance looks far better which is why i switched all the previous wheelsets off & went for a wider rear track
Just off to add to my list.
5 year maintenance package runs out in November and I've kind of been wary of any changes until it has expired. Just not worth the arguments.
- Zedtastic
Have you thought of 16mm? I bought a set of these recently, and the quality was decent...
www.ebay.co.uk/itm/323943566616
F36 435d X-Drive (Daily)
E86 Z4 3.0Si (For dry weekends)
Focus RS Mk1 (In hibernation)
Escort RS2000 Mk2 (In hibernation)
Cortina Mk1, 2.5 turbo (In construction)
- enuff_zed
Bit of a thread revival, as I still need some help.
I have decided to definitely fit 15mm spacers on the rear and leave the front as it is.
But............. all my wheel studs are black.
I can only find spacers with chrome/silver bolts.
My OCD wouldn't cope with different colours front and back, so what options do I have?
Covers? Replacement silver fronts? Or ideally, would prefer longer black bolts for the rears.
Oh, and to clarify further, I don't want black spacers either thank you.
- Smartbear
Hi, you could buy the silver bolts & spray them with black bbq paint. I’ve used it before with good resultsenuff_zed wrote: ↑Fri Nov 22, 2019 8:53 pm Bit of a thread revival, as I still need some help.
e85 3.0si sold
You could just put black covers on, probably the cheapest and quickest way.
I have question regarding the spacers I assume the same set up would work with the 294 model alloys? would 12 or 15mm spacers also work if the car is lowered on eibach or H&R springs? Also some say adding spacers can mess with the other components of the car like wheel bearings etc., what is the experience of those here that have spacers?
- Smartbear
I ran 15/12mm spacers on my 3.0si for a couple of years with no wheel bearing issues but it definitely made the car feel more twitchy, felt like it needed constant correction on motorwaysSilverstar wrote: ↑Sat Nov 23, 2019 12:49 am You could just put black covers on, probably the cheapest and quickest way.
e85 3.0si sold
- enuff_zed
Thanks Rob, worth bearing in mind as its purely the looks I'm after.............................. so is it worth it?Smartbear wrote: ↑Sat Nov 23, 2019 4:32 pmI ran 15/12mm spacers on my 3.0si for a couple of years with no wheel bearing issues but it definitely made the car feel more twitchy, felt like it needed constant correction on motorwaysSilverstar wrote: ↑Sat Nov 23, 2019 12:49 am You could just put black covers on, probably the cheapest and quickest way.
