RFT and nRFT's
Alloy wheels and tyre discussion
alexrives1995
RFT and nRFT's
Post by alexrives1995 » Mon Jul 29, 2019 4:47 pm
Hi all,
I recently purchased my z4 a couple weeks ago. I noticed that it has different tyres on the front and back. On the back it has the Potenza Run Flats, but on the front it has Hancook Ventus V2. Has anyone ran a setup like this? Is this worse than running all four RFTs?
Ride seems fine for me, but i come from less refined vehicles.
ZedConvert
RFT and nRFT's
Post by ZedConvert » Mon Jul 29, 2019 5:00 pm
Don't do it...! I'd be surprised if it's even legal, as it will give you an improper balance... and in my mind will be unsafe at speed, or on severe cornering.
ZedConvert
RFT and nRFT's
Post by ZedConvert » Mon Jul 29, 2019 5:01 pm
BTW- I'd go all non-RFs... and make sure you have a contingency in case of a puncture.
GP06Roadster
RFT and nRFT's
Post by GP06Roadster » Mon Jul 29, 2019 5:45 pm
ZedConvert wrote: Mon Jul 29, 2019 5:00 pm Don't do it...! I'd be surprised if it's even legal, as it will give you an improper balance... and in my mind will be unsafe at speed, or on severe cornering.
That's cobblers. As long as you don't mix on the same axle there are no safety or legal issues!
E86 3.0si Manual
ZedConvert
RFT and nRFT's
Post by ZedConvert » Mon Jul 29, 2019 7:06 pm
GP06Roadster
RFT and nRFT's
Post by GP06Roadster » Mon Jul 29, 2019 7:33 pm
ZedConvert wrote: Mon Jul 29, 2019 7:06 pm Cobblers :rofl:
Anyway, further reading:
https://www.lesschwab.com/article/can-i ... -ones.html
I have potenza RF rear and normal potenza front. Its grips and handles just fine. Doesn't mean I like Runflats though!
E86 3.0si Manual
ZedConvert
RFT and nRFT's
Post by ZedConvert » Mon Jul 29, 2019 7:45 pm
[/quote]
[/quote]
Is that because you still have plenty of tread on the non-RFs, so are waiting to replace them?
do the rears not slide out with the harder compound?
Lazza
RFT and nRFT's
Post by Lazza » Mon Jul 29, 2019 10:57 pm
Mixing is fine as long as it’s not across axles. RFs are bad though so replace when you can.
Also be aware that you will have better wet grip front than rear (Bridgestone RFs are bad) so expect interesting times at wet roundabouts.
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
alexrives1995
RFT and nRFT's
Post by alexrives1995 » Tue Jul 30, 2019 1:00 am
Found out I have one run flat tire only. I have hancooks on the front, a Bridgestone on the driver side rear and a potenza on passenger rear.
Feel as though the car was used in a science experiment haha. Will replace the potenza for sure, the Bridgestone has a lot of tread left.
Lazza
RFT and nRFT's
Post by Lazza » Tue Jul 30, 2019 10:57 pm
Check again. The standard BMW run flats are Bridgestone Potenza RE050.
Z4 S-Drive 35i
Audi TT S-line
Wokingham Berkshire
