Upgrading to bigger 18” wheels
If yes then what would be the best tire combo?
- mr wilks
Yes they will fit & sit very well , assume stock springs E85 then any combination below
215 40 / 225 40 18 front
245 40 18 / 255 35 18 rear
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Thanks mr wilks. I’ve been wanting to upgrade but will the ride really be stiffer coming from 16in wheels? I know the z4 looks dorky with the 16in oem wheels but the ride is great with it.
Will a 17in wheel be a better compromise between ride and looks?
If i would go with the 17in wheels...which tire would be better? 225/35 or 225/45?
- buzyg
I can’t imagine how hard the ride would be if you have run flat tires on 18s...
- dr_john
Not quite as hard as RFT's on 19s...
That's why I went back to non-RFT's on 18s on my new zed, looks aint everything
Sapphire Black G29 2.0 MSport with Technology pack
I found an 18inch squared set of wheels with 245/40 tires on all wheels. Will that fit the fronts or they are to wide?
- road warrior
I found an 18inch squared set of wheels with 245/40 tires on all wheels. Will that fit the fronts or they are to wide?"
a lot of "iffs" in there, iff the ofset is -50 at the front maybe
if the suspension is standard then maybe
if you have new springs and shocks maybe
otherwise you will be grinding down the wheel arch like i did
the rear will be fine
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- Mr Tidy
"Not exactly cossetting" is how I'd describe ride quality on staggered 18s with Bridgestone run-flats!
To see what options will work this might help:- https://www.willtheyfit.com/
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Thanks Mr Tidy....will use that link.
I’ve always liked the style 119 wheels,simple design and is easy to clean...but I never see one on a z4. What are your opinions on these? Will they look good on a black z4?
The 119 wheels were so cheap and it has newer tires so I took the plunge. I think it looks okey on the z4. Ride hasn’t changed much too. At least now I won’t spend so much time cleaning the wheels.
- E7B45EBA-D18E-4005-9CE8-39C9EEB0012C.jpeg (294.49 KiB) Viewed 2128 times
- Mr Tidy
They look good - I'm a big fan of 5 spoke BMW wheels.
And as you say they are so much easier to clean! (Unlike the MV2s my 1st Coupe had).
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Glad somebody liked it... simple and so easy to clean
I really prefer the style 197, it would look good on any BMW...but my back would hurt cleaning that.
