The E89 is going to be heavier than the E85 which has totally different tyre pressure recommendations & can only assume the high psi factors in the weight of the hardtop when stored in the boot therefore over the drive wheels the recommendations as often mentioned in these discussions are there for runflat tyres ( structured with almost solid sidewall) which if ran underinflated can cause them to crease on the inside & therefore become defective , now as for the debate over runflat / non runflat requiring the same pressure that's a whole new debateLazza wrote: ↑Fri Nov 30, 2018 12:16 am My Mazda MX5 has non RF tyres and the recommended pressures are 26psi all round. The car weighs 1280kg. Weight balance 52/48 which i believe is similar to Z4. Around 145bhp which is half of what I have now of course but standard has higher profile tyres (195/50/15 or 205/45/16 or 205/40/17).
Why would the Z4 need an additional 18psi?
Non-RFT pressures
- mr wilks
Non-RFT pressures
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Phoenixboy
Non-RFT pressures
god this is confusingmr wilks wrote: ↑Fri Nov 30, 2018 8:30 amThe E89 is going to be heavier than the E85 which has totally different tyre pressure recommendations & can only assume the high psi factors in the weight of the hardtop when stored in the boot therefore over the drive wheels the recommendations as often mentioned in these discussions are there for runflat tyres ( structured with almost solid sidewall) which if ran underinflated can cause them to crease on the inside & therefore become defective , now as for the debate over runflat / non runflat requiring the same pressure that's a whole new debateLazza wrote: ↑Fri Nov 30, 2018 12:16 am My Mazda MX5 has non RF tyres and the recommended pressures are 26psi all round. The car weighs 1280kg. Weight balance 52/48 which i believe is similar to Z4. Around 145bhp which is half of what I have now of course but standard has higher profile tyres (195/50/15 or 205/45/16 or 205/40/17).
I am going to go f34 r36 when the new goodyears go on car Monday.
worked fine on my R1, so as good a logic as any
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
- Tinker15
Non-RFT pressures
Wow! 23k of bone rattling ride. The roads around you must be a lot better than in Kirklees which is the pothole centre of the North. First we had load, then speed and acceleration and now longevity and consistency. I can’t wait to see what comes next.Busterboo wrote: ↑Fri Nov 30, 2018 12:05 am
Speed apart, using BMW's B-pillar sticker figures + regular wheel alignment gives excellent tyre wear. Not just longevity, but consistency.
So, a pair of Pirelli P Zero rears @ 44psi lasted 23k and still had 2.6mm left across the tread when I changed them.
- Tinker15
Non-RFT pressures
@Phoenixboy
I started of running f34 r36 and then dropped it to f32 r34 which I think is a bit low. I will go back to what I started with. For long motorway journeys and driving through France (80mph is the legal maximum limit on Autoroutes) I will probably go with the Michelin recommendation of f36 r39.
- Phoenixboy
Non-RFT pressures
sounds like a plan, perhaps keep pumping in air til you get bored, and go with thatTinker15 wrote: ↑Fri Nov 30, 2018 10:46 am @Phoenixboy
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Non-RFT pressures
Five years & 50k miles on the hard tyres of a 911 taught me what good chassis & suspension design is and how good good tyres can be.
Slopping round on low pressures in a Z4 does its design no favours.
Vidi, vici, veni
Non-RFT pressures
Looking at the published stats (because I have nothing else to go by) the kerb weight of the 35i is 1580kg. That’s only 300kg heavier than my MX5. That certainly wouldn’t justify something like 80% increase in tyre pressure. That would mean something like my old C Class diesel would need 50+psimr wilks wrote: ↑Fri Nov 30, 2018 8:30 amThe E89 is going to be heavier than the E85 which has totally different tyre pressure recommendations & can only assume the high psi factors in the weight of the hardtop when stored in the boot therefore over the drive wheels the recommendations as often mentioned in these discussions are there for runflat tyres ( structured with almost solid sidewall) which if ran underinflated can cause them to crease on the inside & therefore become defective , now as for the debate over runflat / non runflat requiring the same pressure that's a whole new debateLazza wrote: ↑Fri Nov 30, 2018 12:16 am My Mazda MX5 has non RF tyres and the recommended pressures are 26psi all round. The car weighs 1280kg. Weight balance 52/48 which i believe is similar to Z4. Around 145bhp which is half of what I have now of course but standard has higher profile tyres (195/50/15 or 205/45/16 or 205/40/17).
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- Tinker15
Non-RFT pressures
That’s a good point Lazza! Our Jaguar XF weighs 1810kg has rear wheel drive and a 3.0 litre V6 engine. The Jaguar recommended tyre pressure is 33psi all round.Lazza wrote: ↑Sat Dec 01, 2018 3:06 pmLooking at the published stats (because I have nothing else to go by) the kerb weight of the 35i is 1580kg. That’s only 300kg heavier than my MX5. That certainly wouldn’t justify something like 80% increase in tyre pressure. That would mean something like my old C Class diesel would need 50+psimr wilks wrote: ↑Fri Nov 30, 2018 8:30 amThe E89 is going to be heavier than the E85 which has totally different tyre pressure recommendations & can only assume the high psi factors in the weight of the hardtop when stored in the boot therefore over the drive wheels the recommendations as often mentioned in these discussions are there for runflat tyres ( structured with almost solid sidewall) which if ran underinflated can cause them to crease on the inside & therefore become defective , now as for the debate over runflat / non runflat requiring the same pressure that's a whole new debateLazza wrote: ↑Fri Nov 30, 2018 12:16 am My Mazda MX5 has non RF tyres and the recommended pressures are 26psi all round. The car weighs 1280kg. Weight balance 52/48 which i believe is similar to Z4. Around 145bhp which is half of what I have now of course but standard has higher profile tyres (195/50/15 or 205/45/16 or 205/40/17).
- Phoenixboy
Non-RFT pressures
I honestly believe, and it was the same on the motorbikes, manufacturers will air on the side of caution regarding tyre pressures.
they will not suggest a tyre pressure that could be deemed under inflated, but seem happy to suggest something slightly to high, knowing people are more likely to try a little less than try going harder.
the pressures suggested on my many sports bikes, were always a bit high, and generally talking to the more knowledgeable, you arrived at a good figure that was always less.
as has been said, there are always variables such as suspension set up, type of driving as well as road surface and conditions.
there is usually a happy medium to be found, because one pressure wont cover all the variables.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Non-RFT pressures
I am currently running about 30PSI all the way around on my 2006 2.5si. It has conventional non-RF Goodyear Eagle 3s on the back and Bridgestone Potenzas on the front. I found that reducing the pressures from 35PSI has improved the ride, reduced bump steer and tramlining significantly.
Let's remember that it's a combination of tyres, springs, shocks and other suspension components that all need to work together to give an acceptable ride and grip level. Really high tyre pressures and stiff suspension might improve turn in, but it does nothing for high speed stability and general road holding on typical British roads!
I am sure with RFs, the extra pressure is required to ensure the tyre does not deform, but with conventional tyres a little more flex is quite desirable. Race cars use relatively low pressures 20 - 25 PSI - and they run on generally excellent tarmac. Dropping the tyre pressures has not adversely affected the handling in any perceptible way with my car and I do drive quite energetically
E85 2.5si Sport in dark blue. Calibre CC S wheels
What could possibly go wrong!
- Phoenixboy
Non-RFT pressures
correct, but dropping pressures on track as I am sure you know is because of heat generated on track, hence you then check pressures after a session when tyres are hotnoiseboy72 wrote: ↑Sat Dec 01, 2018 5:24 pm I am currently running about 30PSI all the way around on my 2006 2.5si. It has conventional non-RF Goodyear Eagle 3s on the back and Bridgestone Potenzas on the front. I found that reducing the pressures from 35PSI has improved the ride, reduced bump steer and tramlining significantly.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
- Phoenixboy
Non-RFT pressures
You also get into issues werePhoenixboy wrote: ↑Sat Dec 01, 2018 5:29 pmcorrect, but dropping pressures on track as I am sure you know is because of heat generated on track, hence you then check pressures after a session when tyres are hotnoiseboy72 wrote: ↑Sat Dec 01, 2018 5:24 pm I am currently running about 30PSI all the way around on my 2006 2.5si. It has conventional non-RF Goodyear Eagle 3s on the back and Bridgestone Potenzas on the front. I found that reducing the pressures from 35PSI has improved the ride, reduced bump steer and tramlining significantly.
People fit slick tyres, but aren’t able to ride hard enough to generate the heat required to make them work.
Also then need tyre warmers to avoid the heat cycle issues.
It’s an interesting subject that I learnt through talking to tyre and suspension gurus on track days.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Non-RFT pressures
From what I gather, tyre pressures will go up about 4-6 PSI for a 20 degree rise in carcass temperature - which is all you will get outside of F1 and the like. F1 need to control the ride height very precisely for the aero to work correctly, hence why 0.5PSI could be 1/10 second at some tracks. Not an issue with a road car and on mine the ride height did not change at all with the difference in pressures.
The lower pressures allow more flex and better bump absorption with the main loser being fuel economy. I do wonder whether this is why quite high pressures do get specified...
Non-RFT pressures
Just had new non-rft Eagle F1 asymmetric 3 all round on 225/40/18 and 255/35/18
And set pressures to 2.6bar in front and 2.7 in rear (always thought it was better to go slightly over the pressures on the sticker).
This works out almost 38psi on front and just over 39psi on the rear.
Reading this thread now makes me think they are going to pop!
Being the thicko that I am, was any “average” agreed? I.e 34/36 etc? Don’t want them to wear unevenly and quickly.
2011 E89 sDrive20i
- patriot66
Non-RFT pressures
That's very high in my opinion. I have the same size non-rft tyres and run them at 2.1 bar front and 2.3 bar rear. The car rides well, grip is excellent and they wear evenly across the tread.ihadablackdog wrote: ↑Sun Mar 03, 2019 3:56 pm Just had new non-rft Eagle F1 asymmetric 3 all round on 225/40/18 and 255/35/18
