E85 19” tyre sizes
E85 19” tyre sizes
I’ve done a search and read a few similar discussions, but not found answers to my exact questions.
On a E85 with sport springs, not lowered, with 8x19 ET37 fronts and 9x19 ET39 rears, would 235/35 and 265/35 tyres fit without issue, or rub the arches?
Ideally I would opt for 225/35 fronts, but a set I am considering have good 235s fitted. The rears would need replacing. I don’t like stretched tyres and would prefer 35 profile if possible, although I guess 30 on the rear would give the best match to OE diameter, etc.
- markplant
E85 19” tyre sizes
Have you tried willtheyfit.com put you existing sizes an offset an all new details an it will give you an idea , although experience can be a virtue with this stuff
E85 19” tyre sizes
I have plugged the numbers into that and it quantifies the differences, which is good info. What it doesn’t do though is tell me if rubbing, or other problems will occur in reality.
Onlinemr wilks
E85 19” tyre sizes
With a 8j front you wouldnt need a 235 tyre , 225 35 is fine with no stretched appearance , to be 100% sure of no rub however i would consider 215 35 especially with et37
Rears i would go 255 35 on 9j rims & you won't get any rub off et39
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- thanatu55
E85 19” tyre sizes
Definitely 225 on the fronts (or 215 as mentioned above) and 255 on the rears. I tried 235's on the front first when I got my 19" wheels and they constantly caught on the arches. Looked like I was on tractor wheels too.
I changed to 225 35 on the front and they are perfect. I actually got away with 275 on the back (came with the wheels) without rub but changed to 255 30 to fall in line with BMW's own recommendation.
Edit: Forgot to mention my wheel specs, Rear : 9.5J, offset 35 , Front 8.5J, offset 45
E85 19” tyre sizes
Thanks fellas. Bit of a nuisance though, as it means swapping out an almost new set of 235s, adding a couple of hundred quid to the cost of the wheel change.
E85 19” tyre sizes
I have wheels from a BMW 1M fitted style 359
Fronts are 9” et 31 with 245/35 tyres
Rears are 10” et 23 with 275/30 tyres
The fronts catch the liner when on full left lock in reverse gear.
The rears sometimes slightly catch the arch on large bumps.
The car is lowered with Eibach springs and H&R springs
Current - Z4 MC, M3 CSL, S54 Z3MR, Z1.
Onlinemr wilks
E85 19” tyre sizes
On ZM or non M Z 10j et 23 is gonna look pretty fandango on non MGazza51 wrote: ↑Tue Oct 02, 2018 9:35 pm I have wheels from a BMW 1M fitted style 359
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
E85 19” tyre sizes
On Z4MC as per Sig
Onlinemr wilks
E85 19” tyre sizes
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
E85 19” tyre sizes
That’s interesting, I didn’t know they were different.
I knew the rear end was narrower on the Z3M hence lower et wheels.
Onlinemr wilks
E85 19” tyre sizes
Yep very different on M E85 E86 to non M
8j et 47 front
8.5j et 50 rear on non M
8j et 42 front
9j et 30 rear on the ///M
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
E85 19” tyre sizes
So the body is the same, only different wheel sizes ?
