How old is too old?
How old is too old?
Quick question to get your thoughts on this one....
I drag out a set of winter wheels for my 3 Series every end of November/start of December (obviously weather dependent) and they’ve just gone away today.
I bought the set (wheels and tyres) second hand about 4 years ago, and that’s all the use I’ve had out of them. 9 months (ish) and I didn’t use them last year. Obviously I don’t know what they did before me.
What would you say is old for tyres that get very little use and have no obvious signs of aging, and loads of tread. (You can tell I don’t want to get rid based on age!)
These are runflats, so even if they were to go on me, I’d be ok but it just got me thinking that I may be pushing the life span.
Cheers!
Cheers!
2nd Z4, Auction find, 2007 3.0si Sport, 45k, Silver Grey, 224 Alloys. Retro Cruise
Previous: 2003, 2.5i Sport, Sterling Grey (2006-2010)
- Ducklakeview
How old is too old?
What are the date codes on the tyres? 4 digit code on them..
Mike
Mike
How old is too old?
I’m not telling.....yet!
- Gaffa22
How old is too old?
7 years max from DOT date I have been told
2010 E89 35i DCT
2017 Honda CBR1000RR fireblade
2016 Honda VFR1200F
2016 Honda VFR1200F
How old is too old?
Isn't that for standard wheels though? Also if they've sat about dry in a garage though...no change?
- hopz121
How old is too old?
These are runflats, so even if they were to go on me, I’d be ok.
What do you mean by the above?
Runflats usually are worse at letting go than normal tyres.... blowouts on runflats are actually pretty common.
I'd go with 5 years max maybe 6 years at a push but not much more and they would have to be perfectly stored too.
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- dhobbs
How old is too old?
It's the UV light that degrades them, so if they've been stored inside then they can last longer.
Although if they are showing signs of cracking then probably time to replace.
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
How old is too old?
Well the thinking there is that you're most concerned about a blow out with older tyres, that can't happen with runflats, so you may have it give on you, but you could probably limp on to somewhere safe.hopz121 wrote: ↑Wed Feb 21, 2018 4:48 pm These are runflats, so even if they were to go on me, I’d be ok.
How old is too old?
Yeah, inside, in 'blankets'. Not quite F1 style, but the wrap and tie type.
There's no sign of any aging on them, not that I can see.
- Gaffa22
How old is too old?
I believe the rubber still degrades with time. Certainly UV light is a killer but even if dry and covered the rubber still degrades and goes hard.
2010 E89 35i DCT
2016 Honda VFR1200F
2016 Honda VFR1200F
How old is too old?
Hmmm. Maybe time to “retyre” them then. Will keep the year of manufacture to people’s imagination.
- Tyreman
How old is too old?
Check for signs of age at five years and replacement at ten irrespective of condition, no laws as such but this is the recommendation from the NTDA
- buzyg
How old is too old?
If they look healthy, no cracking. Then they should be good for 7-8 years. Mrs G's cars do about 3 miles a day. We have had cracking, on a few tyres over the years.
- hopz121
How old is too old?
Blow outs can and do happen with Run Flats more so than premium normal tyres to be honest!HyperGrade wrote: ↑Wed Feb 21, 2018 5:16 pmWell the thinking there is that you're most concerned about a blow out with older tyres, that can't happen with runflats, so you may have it give on you, but you could probably limp on to somewhere safe.hopz121 wrote: ↑Wed Feb 21, 2018 4:48 pm These are runflats, so even if they were to go on me, I’d be ok.
How old is too old?
Yeah but as mentioned above, a ‘blow out’ with runflats isn’t as journey ending, as with normal tyres.hopz121 wrote: ↑Thu Feb 22, 2018 9:39 amBlow outs can and do happen with Run Flats more so than premium normal tyres to be honest!HyperGrade wrote: ↑Wed Feb 21, 2018 5:16 pmWell the thinking there is that you're most concerned about a blow out with older tyres, that can't happen with runflats, so you may have it give on you, but you could probably limp on to somewhere safe.hopz121 wrote: ↑Wed Feb 21, 2018 4:48 pm These are runflats, so even if they were to go on me, I’d be ok.
