Wheel buckle
- TopDMC
Wheel buckle
BMW have advised me that I have wheel buckle at the front
I'm on 326 alloys 8J 19"
Seems crazy to buy new wheel at over £500 if it can be repaired!
Three questions.......
- is a repair (assuming it is done professionally) safe and permanent?
- what sort of cost should I be looking at?
- can anyone recommend somewhere reasonably local to Wokingham, Berkshire
I realise that technically that first question was two
Life's for living
- mr wilks
Wheel buckle
Hmmm here's the thing 99% of all wheels need weights to balance , a "buckled" wheel is one that won't balance within certain tolerances of weights . So my first move with your "buckled " wheel would be to take it somewhere independent & ask them to balance it whilst you wait . Watch it on the machine & see what weights are required in order to get a balance . If it won't then yes its feasible to have a wheel straightened but probably easier to buy a single spare off ebayTopDMC wrote: ↑Sun Feb 11, 2018 4:33 pm BMW have advised me that I have wheel buckle at the front
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- cj10jeeper
Wheel buckle
I'd take it that the wheel is buckled as a result of hitting a pothole or similar. A high proportion of larger rims are bucked these days from both increased rim size and as a result lower profile tyres and of course increased numbers of portholes.
You can see it really easily when they are rotated on a tyre balancing machine. You only need hold a pointer close to the rim to see it
Several of mine have been buckled like this and been fixed. The specialist only does it when safe and I've never had a problem.
Get them straightened, refurbed if required, tyre refitted, balanced and save you money
£50 is about the going rate
- Tyreman
Wheel buckle
It's probably flat spotted rather than buckled......very common problem due to the state of the roads, it should be a relatively easy to repair as long as it's not excessive.
As previously mentioned about £50 should cover a repair and rebalance
- mr wilks
Wheel buckle
CJ / Tyreman
Wouldn't it have been noticeable by the driver if the wheel was buckled always wary ( especially where i see mention of Bmw ) that a main dealer has "advised" call me a cynic
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- cj10jeeper
Wheel buckle
All my buckled rims were unknown to me until mounted on a machine and demonstrated.
Never would have known and indeed they could have been refurbished and balanced and I’d be no wiser
- Tyreman
Wheel buckle
Yeah you would be surprised how many wheels are damaged and the driver isn't aware of the issue.........tyre pressure loss is sometimes an indicator
- mr wilks
Wheel buckle
You've lost me there CJ doesn't a buckled rim mean defective therefore affecting its performance or safety ? at which point of course replace or repair ?cj10jeeper wrote: ↑Sun Feb 11, 2018 6:39 pm All my buckled rims were unknown to me until mounted on a machine and demonstrated.
If you can't feel a buckled or unbalanced wheel when driving then are you not looking for a solution to problem that isn't there by having it straightened ?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- cj10jeeper
Wheel buckle
Well a few thoughtsmr wilks wrote: ↑Sun Feb 11, 2018 6:50 pmYou've lost me there CJ doesn't a buckled rim mean defective therefore affecting its performance or safety ? at which point of course replace or repair ?cj10jeeper wrote: ↑Sun Feb 11, 2018 6:39 pm All my buckled rims were unknown to me until mounted on a machine and demonstrated.
Just because you can’t tell something is out doesn’t mean you don’t fix it. My XF suspension is good at masking things. My F may have buckled I don’t yet know about... When spotted at wheel refurb time I fix them
Doesn’t mean performance is immediately compromised or dangerous either. Alloy is soft and bend on big wide rims
Would you know if a rim was cracked or spring broken until someone spotted it during a test? Probably not
Don’t mix out of balance and buckled. One is cause one effect.. Just think your confusing yourself here
- Ducklakeview
Wheel buckle
Personally, unless it's just extremely minor, and on the rim edge - I would never have one repaired. The alloy work hardens very quickly when it is manipulated, and becomes brittle. I've done it in the past with steel rims, but never with an alloy.
Mike
Mike
- mr wilks
Wheel buckle
No i don't think i am Simply curious why a balanced wheel would need to be put in for "unbuckling" if the driver had felt nothing whilst on the roadcj10jeeper wrote: ↑Sun Feb 11, 2018 7:25 pm
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- TopDMC
Wheel buckle
I reckon Inknow exactly where this was done. I remember a massive thump from a pothole and expected the tyre pressure to go down with the probability of a crack. It happened about 3 months ago and I can probably find it on the dash cam. Can’t imagine that I could prove it to the council, so long after the event.mr wilks wrote: ↑Sun Feb 11, 2018 7:35 pmNo i don't think i am Simply curious why a balanced wheel would need to be put in for "unbuckling" if the driver had felt nothing whilst on the roadcj10jeeper wrote: ↑Sun Feb 11, 2018 7:25 pm
Don’t notice any problem when driving, and continue to take corners without vibrations. The tires appear to be wearing (according to the BMW service) in an even manner.
Do I really need to repair? Everything seems fine, no loss of pressing and no vibrations.
Sent a mail to Henley auto care, I found them from google and they replied telling me they could repair a buckle, take about 2 hours and cost between £60 and £80. Anyone with any experience of these guys?
Life's for living
Wheel buckle
No experience of the guys you mention but these guys are excellent, https://www.thewheelspecialist.co.uk/lo ... aidenhead/
They also have branches in Kingston, Farnham and Fareham if those are nearer ....
https://www.thewheelspecialist.co.uk/al ... el-repair/
Cars: E89 Z4 3.0i M Sport, VW Scirocco 2.0 GT TFSI
Bikes: Ducati 996, Ducati 999R Fila, Ducati Multistrada, Ducati Panigale 1199S
Pets: Charlie and Luigi the cats.
Wife: Just the one.
Instagram: Dibblecorse
Wife: Just the one.
- MACK
Wheel buckle
I'm with you here, we all know main dealer mechanics are a bunch of muppets and mercenaries. Be intersted to hear what the OP took the car in for in the first place. Interesting that a 326 buckled rather than cracked. They usually seem to cracked first
Silver 05 3.0i SE
White E89 20i M Sport
- Joycey
Wheel buckle
I've had quite a few wheels straightened, pot holes are a nightmare where I live. Paid £75 a months back.
