Tbh, I wanted to say MV2, as I don't see why I should be the only one knackering my fingers every time I clean the car.
Ive been looking at the 18”, as the design is very forgiving and the thin lips make them look bigger than they are (best of both worlds). Set I’ve found isminimental wrote: ↑Tue Jan 12, 2021 9:58 am M4 reps for me too, for all the reasons listed above!
i don't know what sizes you were after (they seem to come in 18,19 and 20 on eBay but they all seem to have offset in the 40's so may need some spacing to get them sitting flush
I'm new at clearances and offsets, so bear with me - and I'm sure somebody will be along soon to put me right - however....M340 wrote: ↑Tue Jan 12, 2021 11:18 amIve been looking at the 18”, as the design is very forgiving and the thin lips make them look bigger than they are (best of both worlds). Set I’ve found isminimental wrote: ↑Tue Jan 12, 2021 9:58 am M4 reps for me too, for all the reasons listed above!
Front - 18 x 8 ET40
Rear - 18 x 9 ET48
....which compared to 108”s, I think pushes them out a few mm front and rear. Maybe needs a set of 5mm-7mm spacers to get perfectly flush...?
so after messing around with clearances and fitments i might be able to help a bit, it made it easier for me to understand by working out the equivalents so et48 on a 9j would be the equivalent of et42 on an 8.5j so about 8mm more poke than stock (et50 on an mv2) fronts will be 7mm further out (et47 on mv2) i think you commented on a previous post you were going for a flush fitment mine is pretty flush (i haven't done enough mileage to confidently say they 100% do not rub but no signs at all so far!)inkey$ wrote: ↑Tue Jan 12, 2021 12:01 pmI'm new at clearances and offsets, so bear with me - and I'm sure somebody will be along soon to put me right - however....M340 wrote: ↑Tue Jan 12, 2021 11:18 amIve been looking at the 18”, as the design is very forgiving and the thin lips make them look bigger than they are (best of both worlds). Set I’ve found isminimental wrote: ↑Tue Jan 12, 2021 9:58 am M4 reps for me too, for all the reasons listed above!
Front - 18 x 8 ET40
Rear - 18 x 9 ET48
...compared to my MV2s (8.5 x ET50) the 18 incher's look like the come out 8mm at the rear with the offset shown (9 x ET48) and with 4mm less inner clearance. Maybe a 10mm spacer at the rear if you really wanted to push the boat out in terms of arch flushness.
At the front the MV2s (8 x ET47) whereas the M4 reps are (8 x ET40) mean the wheel will extend out an extra 7mm and give 7mm more inner clearance, so I would guess probably wouldn't need any spacing out.
Yeah exactly, so at that offset they should fit pretty nicely....and only minimal spacers if any
Online everywhere or CM Wheels do them.
They’re the puppies.ph001 wrote: ↑Wed Jan 13, 2021 7:03 am, are these the ones:
https://cmwheels.com/product/19-763m-m4 ... er-silver/
