Retrofit Interior foot lights M54 2.2i 2004
CUREthe
Post by CUREthe » Mon Dec 30, 2013 11:06 pm
Hello,
my Zed is just 2.2i (5/2004) from factory and does not have lighting for the area of the passenger feet, and driver.
I wanted to install this type of lighting but do not know where to turn.
I read here in the forum that was only buy the light and connect the cable that was already from factory.
Anyone can help me?
Some pictures from passenger side:
and driver side:
Glovebox dont have interior light to, its normal?
p.s.: sorry my english... :oops:
Smart Pulse CDI 02' Bay Grey
BMW E30 316i 90' Delphin Metallic
BMW E85 2.2i Roadster 04' SterlingGrau Metallic
CUREthe
Re: Retrofit Interior foot lights M54 2.2i 2004
Post by CUREthe » Thu Jan 02, 2014 10:51 pm
hello again!!
Already I found the two points of light. the driver's side and passenger too. :D :D
after meth photos for y'all to see! :thumbsup:
aquazi
Post by aquazi » Fri Jan 03, 2014 11:21 am
:thumbsup:
Glad you found them!
Sent from my iPhone 5s using Tapatalk
paddy wright
Post by paddy wright » Fri Jan 03, 2014 11:55 am
The wiring is taped up- if you route around it will be there- I have done this.
CUREthe
Post by CUREthe » Fri Jan 03, 2014 1:09 pm
aquazi wrote::thumbsup:
thanks! :D
paddy wright wrote:The wiring is taped up- if you route around it will be there- I have done this.
i found the wiring, its really easy. :oops: :D
And I found two more cables on the driver side that I do not know what they are for...
srhutch
Moderator
Moderator
Post by srhutch » Fri Jan 03, 2014 2:25 pm
CUREthe wrote: And I found two more cables on the driver side that I do not know what they are for...
Depending where you found them they could be fore cruise control.
CUREthe
Post by CUREthe » Fri Jan 03, 2014 6:34 pm
my car have cruise control. :)
one picture from waring and connectors.
the little one is for foot ligths. :thumbsup:
the other two connectors I dont konw... :roll:
cj10jeeper
Post by cj10jeeper » Fri Jan 03, 2014 6:42 pm
The 2 connectors you show plug into the sounder which is a small speaker unit in the panel just below your knees.
They both provide warnings and alarms. One does seatbelt or PDC warnings and I think speed limit if set and the other to indicate you are in reverse. The reverse warning is horrible and best left disconnected
CUREthe
Post by CUREthe » Fri Jan 03, 2014 7:02 pm
cj10jeeper wrote:The 2 connectors you show plug into the sounder which is a small speaker unit in the panel just below your knees.
I dont have that small speaker... :roll: :roll:
my car doesn´t warning when I drive without seatbelt. The first owner told me he had take this function from car. :headbang:
thanks for information cj10jeeper!! :thumbsup: :thumbsup:
T2FFN
Post by T2FFN » Fri Jan 03, 2014 7:19 pm
Mines a 3.0i and doesn't have a glove box light either. I'd like to retrofit something, even an LED strip in there but there isn't a blank plate or anything so I imagine there's no wiring either. (Or sensor to know when to turn on/off)
3.0i
cj10jeeper
Post by cj10jeeper » Fri Jan 03, 2014 7:24 pm
You need part 8360995
Lots in eBay and cheap enough to fit and check not works.
Can't recall exactly which warnings use this sounder
CUREthe
Post by CUREthe » Fri Jan 03, 2014 9:37 pm
thanks for your help! :thumbsup: :thumbsup:
I go buy one! :D
CUREthe
Post by CUREthe » Thu Jan 30, 2014 7:27 pm
hello again!
After buy the small speaker and the footwell lights I install them in the Zed... I'm very satisfied. :D
Thanks for your help guys! :thumbsup: :thumbsup:
8)
