E89 rear fog light install
Z4e89uk
Post by Z4e89uk » Wed Mar 01, 2017 9:29 pm
Hi I have a USA spec 35is now in the uk need to get the rear fog light working have UK rear lights and euro light switch with rear fog light my car has 6 wires at the switch but it needs 7 have added the extra wire to the switch using a multimeter but need to know where it goes and how to recode the module I have software to do the programming also want to turn drl off thanks
Smartbear
Post by Smartbear » Wed Mar 01, 2017 9:37 pm
Z4e89uk wrote:Hi I have a USA spec 35is now in the uk need to get the rear fog light working have UK rear lights and euro light switch with rear fog light my car has 6 wires at the switch but it needs 7 have added the extra wire to the switch using a multimeter but need to know where it goes and how to recode the module I have software to do the programming also want to turn drl off thanks
I think I could turn my drl off from the obc stalk & scrolling through the options?
e89 Sdrive2.0 20i, plenty of mumbo & good economy-the thinking bears z4 :P
e89 Sdrive30i this ones busted, pass me another...
e85 3.0si, i foolishly sold my trouble free car...
*AL*
Post by *AL* » Sun Mar 05, 2017 7:48 pm
Curious, why would you want to turn the DRL feature off?
2009 (59) Z4 E89 3.0i Sdrive in deep sea blue, white extended leather, I-drive, folding mirrors. Suzuki GSX 1300R Hayabusa
dirklagos
Post by dirklagos » Thu Jul 06, 2017 10:08 pm
I also have an E89 from USA now in Portugal and need to do the same. I installed the switch with fog lamp option but need to know else is required????
Bobsealbeach
Post by Bobsealbeach » Wed Dec 26, 2018 9:33 pm
Did you ever get a response? I've added the switch and no results. US E89 35i. I have the programming Carly device also if there is a specific item that needs to be changed.
Frustrating. This was easy on my M3 and X1.
clarker63
Post by clarker63 » Thu Dec 27, 2018 10:44 am
If its anything like the time I added heated seats to my E89 I had to update the JBE module to enable them, despite it not obviously being related to the JBE module (I had added the codes to the other modules, but the passenger seat just didn't work - when I loaded the JBE and coded it, with no changes, a click was heard in the JBE and then it worked). I guess if you're running the cable from the switch directly you'd have expected it to work though!
Retrofited : LCI Repeaters, Cruise Control, Heated Memory Leather MSport seats, Stubby (Whippy kept for posterity!) :D
AngryZed
Post by AngryZed » Tue Feb 05, 2019 6:20 pm
I did this for an E85 for the same reasons as you, I believe at the time when I did this mod, E86 was the same procedure (Not positive on E89). Few ways you can go about, I coded mine to enable it and no extra wires were needed. Replace your LSZ or facelift it (much easier) and code away. I'm assuming you already have it worked out, so I'm not adding more.
2005 E85 3.0i 6sp Manual Black USA spec.
2008 Cbr 600-RR - Track use - back home
1994 Cbr 600 F2 - Sold
