Andy,You can't receive PM's yet so contact me on removed << remove the spaces
How-To - e89 Cruise Control Retro-fit
Dave
2011, 23i, Grey with Red leather.
- Cymberline
Hi. I have just purchased my first z4. 2016 2.0i with alas no cruise control. Will the Ebay item - slip ring/stalk cluster as mentioned by mholt1995 also be correct for mine. All the ones on ebay say not compatible such as this one https://www.ebay.co.uk/itm/BMW-3-Series ... SwFTddOV4b Mine does have bluetooth and sat nav if that makes a difference. Thanks for your work, you have spent a lot of time on this.
2016 white Z4 2.0i auto red leather
1991 white mx5 1.6 mk1 (Sold )
Yes that will fit an e89 Z4.Cymberline wrote: ↑Fri Jul 26, 2019 9:59 pm Hi. I have just purchased my first z4. 2016 2.0i with alas no cruise control. Will the Ebay item - slip ring/stalk cluster as mentioned by mholt1995 also be correct for mine. All the ones on ebay say not compatible such as this one https://www.ebay.co.uk/itm/BMW-3-Series ... SwFTddOV4b Mine does have bluetooth and sat nav if that makes a difference. Thanks for your work, you have spent a lot of time on this.
One thing to check, that unit is for a car with auto wipers (as denoted by the letter 'A' on the wiper stalk. As long as you have auto wipers it'll be fine, if not then look for one that has the three dashes instead '---'
Dave
- Cymberline
Thanks, yes have got auto wipers. I was a bit worried about the year as none of the stalks mention being compatible for 2016. So looks like I will have to take the plunge. Thanks again. ChrisYes that will fit an e89 Z4.
Hi Chris,Cymberline wrote: ↑Sat Jul 27, 2019 11:54 amThanks, yes have got auto wipers. I was a bit worried about the year as none of the stalks mention being compatible for 2016. So looks like I will have to take the plunge. Thanks again. ChrisYes that will fit an e89 Z4.
Don't worry one that'll fit a 2009 will fit a 2016 Z4 and work exactly the same because they are all the same.
Dave
Hi. How do i contact you, I’m v v interested in having cruise control fitted.
Regards
Gary
Regards
Gary
Sorted, you have mailGary Rounds wrote: ↑Sun Aug 04, 2019 6:53 pm Hi. How do i contact you, I’m v v interested in having cruise control fitted.
Regards
Gary
Dave
Been busy this afternoon, cleaned up some new stock, nice n shiny now ready for customers, two are already booked out but I can normally get replacements fairly quickly.
Don't forget if anyone wants cruise control fitting just give me a shout
- 20190809_155748.jpg (163.99 KiB) Viewed 3380 times
Dave
Hello,
I am Cor and recently bought an e89 without the cruise-control.
I did read this item and want to retrofit the cruise-control myself, did earlier coding on my e85.
So i'm wondering if there is a fallback if it's not working?
I suppose just put back the original switches and put back the original man file, but what about the
other settings?
other settings?
So long as you follow the instructions then you shouldn't have a problem, the only issue would be a faulty switch set.cvhuis wrote: ↑Wed Oct 30, 2019 7:02 pm Hello,
other settings?
But yes you would replace the original file. As for anything else then it wouldn't matter.
Dave
Hi Cor,cvhuis wrote: ↑Wed Oct 30, 2019 7:02 pm Hello,
other settings?
Did a retrofit myself six months ago. Followed all instructions, everything went without any issues, except code all modules (had to do it module by module). Ordered the steering column switch donored from an E90 (numbers matched) and used the existing coil spring cartridge, so no need to buy a new one.
I am located in Amsterdam and I do still have the original stuff which came off my E89. Might be helpful in case you should break something
Hi I have recently purchased a e89 2.5 2009, a fantastic car, but I would love to have cruise control fitted, I have come across your post on this forum and was hoping you might be able to help. I understand you have the equipment etc, I’m a complete techno fob and would really appreciate your help, I live in Suffolk to not to far away.
I look forward to hearing from you and hope we can sort something out.
Kind Regards
Ashley Watson.
Kind Regards
Ashley Watson.
Ashley,dockboy wrote: ↑Thu Nov 28, 2019 8:51 pm Hi I have recently purchased a e89 2.5 2009, a fantastic car, but I would love to have cruise control fitted, I have come across your post on this forum and was hoping you might be able to help. I understand you have the equipment etc, I’m a complete techno fob and would really appreciate your help, I live in Suffolk to not to far away.
Kind Regards
Ashley Watson.
You should receive an email from me (via the forum) very soon with details
Dave
Ok lovely many thanks
Hi guys, I've recently retrofitted cruise to my 2013 2.0i using Dave's excellent guide. When setting the cruise, should there be a light on the speedo showing the set speed as per the owners manual, or is it just the central display that comes on for 2 seconds then goes out?
Jon
Jon
E89 2.0i LCI - Valencia Orange
