Poorly 35i (Now Fixed)(sort of)
dario
Poorly 35i
Post by dario » Sat Sep 16, 2017 5:21 pm
Maniac wrote:
Sat Sep 16, 2017 4:51 pm
I borrowed a friends adaptor from work and it found nothing.
Ok my quest for a code reader continues.
35i - DCT - Most of the toys - Smart top roof module - GLF.
Maniac
Poorly 35i
Post by Maniac » Sat Sep 16, 2017 5:32 pm
I did get a cheap wifi job ages ago but that needs Carly (I have lite which is practically useless).
dario
Poorly 35i
Post by dario » Sun Sep 17, 2017 6:27 pm
cheers
R.E92
Poorly 35i
Post by R.E92 » Tue Sep 19, 2017 5:07 pm
dario wrote:
Sat Sep 16, 2017 4:16 pm
Hi Manic,
on a different point what code reader are you using and is it any good.
I need to clear my airbag light on my 5 series GT F07 and the dealers want £30 with is a good price IMHO, but i'd like to put this toward a reader/ fault clearing device as with my Z4 and F07 and my daughter cars, adding another £40-50 might be a better idea as then i'll be able to read and clear faults on all cars (i think)
cheers
If you are comfortable with computers and have a laptop then I would recommend getting a virtual machine with a copy of ISTA Rheingold installed then buy a "bimmergeeks" DCAN cable. The BMW virtual machine containing all the software can be found in the coding section of E90post.
If you're not IT literate and have an Android phone then just buy the "MHD Flasher N54" app and a bimmergeeks cable and use that for code reading. It picks up all BMW specific codes and allows resets of all codes and engine adaptations.
I wouldn't bother with Carly. I was never impressed with its code reading abilities.
dario
Poorly 35i
Post by dario » Tue Sep 19, 2017 5:22 pm
Hi Manic,
cheers
Thanks for the good info. Decided to let the dealer do it for £30. That way is done. Cheers
Maniac
Poorly 35i
Post by Maniac » Sun Oct 01, 2017 8:07 pm
Took the car to Bmw on Saturday. Actually ran really well.
Right up until it started to slow down and the accelerator pedal no longer functioned, quickly followed by an amber warning about engine overheat.
The car went from 60 to 50 to 40 to 30 (motorway!) and i pulled into the hard shoulder doing 20mph at full throttle (made no difference) finally got stopped and waiting 10 mins. Started car and carried on within hard shoulder at 20mph until I stopped again. Waited another 10 mins before it would start again and limped the rest of the way at 20mph (car would not exceed this) and as I rolled into the dealership I got a red ‘stop immediately’ .. which I did.
This is going to be fun. Time for a Lexus?
dario
Poorly 35i
Post by dario » Sun Oct 01, 2017 8:35 pm
Well there going to find something now! Glad you got extended warranty?
Smartbear
Poorly 35i
Post by Smartbear » Sun Oct 01, 2017 8:38 pm
Electronic water pump a la n52? Hope it's not too expensive :cry:
e89 Sdrive2.0 20i, plenty of mumbo & good economy-the thinking bears z4 :P
e89 Sdrive30i this ones busted, pass me another...
e85 3.0si, i foolishly sold my trouble free car...
mr wilks
Poorly 35i
Post by mr wilks » Sun Oct 01, 2017 9:03 pm
He has warranty , otherwise if not its circa £1000 :cry:
Z history
E86
E85
Grey///MR
Si E85
E89 23i
Si E85
E86
3.0Si E85
Imola///MR
35i Msport 6spd
E86
Ti ///MR
E86
https://www.instagram.com/andybmwheels/
ph001
Poorly 35i
Post by ph001 » Sun Oct 01, 2017 10:30 pm
Water pump for sure. £250 + fitting.
2004 E46 M3 coupe manual.
Maniac
Poorly 35i
Post by Maniac » Mon Oct 02, 2017 7:44 am
Seems unlikely if the water pump has failed that it would have contributed to the misfire and hesitation when cold? Coincidence?
mr wilks
Poorly 35i
Post by mr wilks » Mon Oct 02, 2017 5:40 pm
On a 35i :? you sure about that ? for the N54 twinturbo they are £495 for the pump alone on ECP :cry:
I have a invoice with my 35i for it replacing last year & its over £1100 from a Indy :(
Z history
E86
E85
Grey///MR
Si E85
E89 23i
Si E85
E86
3.0Si E85
Imola///MR
35i Msport 6spd
E86
Ti ///MR
E86
Smartbear
Poorly 35i
Post by Smartbear » Mon Oct 02, 2017 6:00 pm
On a 35i :? i have a invoice with my 35i for it replacing last year & its over £1100 from a Indy :(
Hmm, just had a quick look & they don't seem a crazy price-if it's like the N52 (looks like it's very similar externally fitted unit) it could be done & dusted within an hour :?
https://www.ebay.co.uk/i/281811971336
mr wilks
Poorly 35i
Post by mr wilks » Mon Oct 02, 2017 6:01 pm
Amended my post above as you were writing Rob :oops: think £350/£385 more probable but id be surprised if it is waterpump in this case
Z history
E86
E85
Grey///MR
Si E85
E89 23i
Si E85
E86
3.0Si E85
Imola///MR
35i Msport 6spd
E86
Ti ///MR
E86
Z4M-2006
Poorly 35i
Post by Z4M-2006 » Mon Oct 02, 2017 6:23 pm
The cold start and hesitation will be injectors...
Water pump will be overheat problem.
If you have warranty,dont sweat it.......Both common probs on the N54.
