Water ingress e89
Watson
Water ingress e89
Post by Watson » Sun Feb 07, 2021 10:05 pm
ric19 wrote: Sun Feb 07, 2021 9:06 pm I bought one of the foam cradles direct from BMW yesterday for £21 .. there were 2 more in the country so if you want one be quick
Thanks for the heads up
I will be on the phone first thing in the morning
ric19
Water ingress e89
Post by ric19 » Sun Feb 07, 2021 10:20 pm
NP..Let us know when you find the grommet please
Smartbear
Water ingress e89
Post by Smartbear » Sun Feb 07, 2021 10:25 pm
Pondrew wrote: Sun Feb 07, 2021 9:40 pm
You can add an led strip to improve the boot lighting :thumbsup: [/quote]
That's a very good idea. As it happens I have 5 metres of 12v dc led strip left over from illuminating my recently installed wardrobes. I think I will wait until the weather warms up a bit though! :)
[/quote]
The pic i posted was poor, just been out & taken one that shows off the brightness better. It makes a big difference :thumbsup:
e85 3.0si sold
Pondrew
Water ingress e89
Post by Pondrew » Sun Feb 07, 2021 10:45 pm
Smartbear wrote: Sun Feb 07, 2021 10:25 pm
[/quote]
[/quote]
You want to shut that quick, in case you get water ingress! :P Is that blue LED?
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
Pondrew
Water ingress e89
Post by Pondrew » Sun Feb 07, 2021 10:49 pm
Rob, (may I call you Rob or is it Mr Smartbear),
Did you wire the leds direct into the battery? If so, did you put an inline fuse in?
Strike that. You would have taken it from the boot light, so it's activated by the switch. Sorry I'm being a t*t. I blame lockdown and a lack of cerebral stimuation! (or any kind of stimulation) :D
F31 320i. Good car.
Mazda3 sold
Smartbear
Water ingress e89
Post by Smartbear » Sun Feb 07, 2021 11:10 pm
Pondrew wrote: Sun Feb 07, 2021 10:49 pm Rob, (may I call you Rob or is it Mr Smartbear),
Rob to my friends, so you can call me smartbear :P
Yes, spliced into the existing boot light wiring to the r/h side of the battery. I’m surprised it looks so blue, it’s a white light but must be a “cool white” :thumbsup:
e85 3.0si sold
Pondrew
Water ingress e89
Post by Pondrew » Sun Feb 07, 2021 11:24 pm
Smartbear wrote: Sun Feb 07, 2021 11:10 pm
Pondrew wrote: Sun Feb 07, 2021 10:49 pm Rob to my friends, so you can call me smartbear :P
Dunno, Mr Smartbear, it doesn't look that cool! :P
F31 320i. Good car.
Mazda3 sold
Pondrew
Water ingress e89
Post by Pondrew » Sun Feb 07, 2021 11:26 pm
anyway :hijacked:
F31 320i. Good car.
Mazda3 sold
Silverstar
Water ingress e89
Post by Silverstar » Mon Feb 08, 2021 2:07 am
I did the same some time ago, adding the LED strip really does make a huge difference. Thread on it here:
viewtopic.php?f=46&t=119849&hilit=boot+light
Watson
Water ingress e89
Post by Watson » Mon Feb 08, 2021 6:06 pm
ric19 wrote: Sun Feb 07, 2021 10:20 pm NP..Let us know when you find the grommet please
Found the grommet
I thought I had dried out the battery void completely so was surprised at amount of water which came out
The grommet is on the nearside ( passenger) next to heat shield for exhaust , I tapped it with the torch and water started pouring out although battery well was dry
I have put the grommet back in but left it at an angle so any further water will leak out while still stopping dirt/ water entering
Sorry about pics not much room under the Z
ric19
Water ingress e89
Post by ric19 » Mon Feb 08, 2021 6:21 pm
Brill, thanks for that, when the snow has passed i will get under and take a look, I use an Oil Pump to get the excess water out at the mo ..bit like this one https://www.amazon.co.uk/Manual-Syringe ... B07Y5C57KK
ric19
Water ingress e89
Post by ric19 » Mon Feb 08, 2021 6:28 pm
I wonder if it would be possible to make a permanent drain with another grommet with a pipe in the middle to allow water out but not in ?
Watson
Water ingress e89
Post by Watson » Mon Feb 08, 2021 6:46 pm
It would be possible but would need doing from underneath as drain plug is not accessible from battery compartment
I may put the plug back in and drill a small hole in centre of grommet , just enough to let water drain out
Wish I had found the grommet yesterday before spending 30 minutes mopping it up with a sponge and wringing it out in -3 temperatures
Took boot seal off today and resealed with silicone so will see how that works next time it rains
ric19
Water ingress e89
Post by ric19 » Mon Feb 08, 2021 6:49 pm
Nor sure if you saw my comment on FB but the boot vents are also a known leak source..I've bought some new ones as apparently they were redesigned at some point..trouble is the rear bumper has to come off to gain access so it's a job I've lined up for spring..11 quid each from BMW if you need them
Watson
Water ingress e89
Post by Watson » Mon Feb 08, 2021 8:14 pm
Hopefully the silicon does the trick on the boot seal , the old stuff had deteriorated and turned to dust
Picked up a new foam roof motor housing today but taking no chances it is placed insides a plastic bag then sealed with cling film around the bottom
Time will tell
