Rear Rattle
Rear Rattle
One of the two plastic clamps fixing the bar to the felt tray? If that's loose then a) common fault and there's a post on here about drilling it out and putting metal bolts where BMW cheaped out on plastic ones that fail and b) yes could well cause the sound you hear.
Online
Rear Rattle
Welcome to the World of E89 rattles.
My latest one this last week a plastic rattle over on the left. I have wedged a piece of rubber in the bottom corner between the dash and the cheap looking window frame trim that goes up the door frame. Fingers crossed that that is the culprit.
Noise I have managed to cure in past
1/Rear deck tapping in the corners near the flappy bits. Sounded like two sandwich boxes banging together. Glued rubber on the underside.
2/That wedge thing below the rear window that sits in the hole in the rear deck. Some fluffy stick on pads either side, not the wedge though, otherwise the window won't lift. It originally had some very thin felt on the wedge bit, but fell off.
3/The roof protector hinges broke so fixed with carriage bolts and nuts.
4/Every gap in plastic trim sprayed silicon.
5/Sun visors rattle, mirror cover inside rattles. Used some rubber pads on window frame to stop this.
6/iDrive screen motor gears rattle, cured with silicon spray.
7/Wedges the roof sits on covered in thin rubber.
8/Having seats too far back they bang against rear bulkhead.
9/Sometimes sound of loose washers in steering column.
10/Trim under dash rattles, silicon spray and wedged a piece of card where there was a loose electrical module, above drivers right leg.
11/ Bonnet rattle, adjusted the bonnet rubbers.
Anything left lose rattles, probably due the stiffer ride.
Sometimes dropping the windows half inch cured some noises. Think that is related to 7/.
I think the rear quarter light black bit butts up against a bolt head in the door window rubber trim. Poke a finger in and you can feel the bolt head.
Recently had all the rear bulkhead trim out to fit pass through storage, that was a quiet week with that all removed.
A more serious rubber mallet bumping sound in boot finally cured by, replacing the anti roll bar bushes with polybushes, then replacing the rear shocks with Bilstein and finally removing the right rear spring, washing the rubbers top and bottom, chalked them, refit and set the spring 90 degree anti-clockwise from original position.
Other than the rubbish steering, partly cured by fitting non-rft's and the notchy gearbox, it's a great car
- adann
Rear Rattle
Had a look but can't find it, was it a recent post?Maniac wrote:One of the two plastic clamps fixing the bar to the felt tray? If that's loose then a) common fault and there's a post on here about drilling it out and putting metal bolts where BMW cheaped out on plastic ones that fail and b) yes could well cause the sound you hear.
BMW Z4 23i
Rear Rattle
Here's another...adann wrote:Had a look but can't find it, was it a recent post?Maniac wrote:One of the two plastic clamps fixing the bar to the felt tray? If that's loose then a) common fault and there's a post on here about drilling it out and putting metal bolts where BMW cheaped out on plastic ones that fail and b) yes could well cause the sound you hear.
http://e89.zpost.com/forums/showthread.php?t=733794
- adann
Rear Rattle
Thanks so much for your help, will have a bash at this tomorrow and see what happens.Maniac wrote:Here's another...adann wrote:Had a look but can't find it, was it a recent post?Maniac wrote:One of the two plastic clamps fixing the bar to the felt tray? If that's loose then a) common fault and there's a post on here about drilling it out and putting metal bolts where BMW cheaped out on plastic ones that fail and b) yes could well cause the sound you hear.
BMW Z4 23i
Onlinemr wilks
Rear Rattle
flybobbie wrote:Welcome to the World of E89 rattles.
I wouldn't have got past no4 , that car would have been up the road
Applause for tenacity to get the faults fettled , maybe I got lucky with my 89 125k on & nothing rattles or squeeks
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Online
- adann
Rear Rattle
Thanks for that. Hoping this is what the problem is, noise is driving me mad!
BMW Z4 23i
Online
Rear Rattle
"My latest one this last week a plastic rattle over on the left. I have wedged a piece of rubber in the bottom corner between the dash and the cheap looking window frame trim that goes up the door frame. Fingers crossed that that is the culprit."
Yep, wedging the rubber in the gap has stopped the rattle.
Have some edging trim that fits nicely in the gap to fit tomorrow.
- jleckenby
Rear Rattle
Hi mate,flybobbie wrote: ↑Sat Jun 25, 2016 9:31 pm Welcome to the World of E89 rattles.
Where abouts did you spray the idrive to stop it rattling? Cant see any exposes gears or anything.
James
Z4 35is, 438bhp
Cobb Stage 2 (Aggressive), VRSF Catless Downpipes, BMS DCI, NGK Iridium Spark Plugs, Eibach Springs
Online
Rear Rattle
Look to the right, see a gap, can see the gears.
Rear Rattle
Re: 7flybobbie wrote: ↑Sat Jun 25, 2016 9:31 pm
At slow speeds (upto 50mph) with roof and windows up, I hear a rattle from back of the left ear. I looked everywhere and concluded it goes away when windows are lowered a little. So I believe this rattle is caused by windows pushing against the roof? I checked the rubber sealing, Gummy pfleged it and still no change. I also added some foam and felt in the area and didnt help much.
Any ideas for how to fix it?
Rear Rattle
Hi there new to the site so apologise for jumping in and have read some of the responses but maybe slightly different with my 2014 2.0 only just starting hearing creeking noises from behind drivers side, sounds like plastic on plastic? tried putting sponge between roof and rear 'roll bars' but didn't change then realised it was the same with the roof down
Rear Rattle
Pagie wrote: ↑Mon Nov 18, 2019 12:51 pm Hi there new to the site so apologise for jumping in and have read some of the responses but maybe slightly different with my 2014 2.0 only just starting hearing creeking noises from behind drivers side, sounds like plastic on plastic? tried putting sponge between roof and rear 'roll bars' but didn't change then realised it was the same with the roof down
The overalling trim around the rear bulkhead is held in with a few piss poor push clips..the two layers of trim can rub against each other, I padded them /preloaded them with a few zip tie pieces cut up and wedged in between them..there may b emore sophisticated ways of doing that and/or lots of places to squeak back there!
Rear Rattle
Hi, have just purchased Z4 E89 2015 & am experiencing same rattle in the boot area (the run-flat tyres also give a hard ride but this is just a character of the car). Does not happen with roof down. Have checked all roof mechanisms which seem solid & tight (as new) so would not be the cause. I suspect the rattle may be coming from the boot partition section where you push down both sides to lock in position to be able to lower roof??? Does anyone also have this issue & what was the cure - padding out / making any adjustments, etc.......? Any help appreciated thanks...
