Hardtop roof issues. 2013 plate
Z4x40J
Post by Z4x40J » Fri Mar 27, 2015 8:25 am
Hi all. Just purchased my first Z4 - having issues with the roof warning light coming on & a message telling me the hardtop is not latched. The roof is up when this occurs. However I've had the roof get stuck down, so when you go to put the roof back up the rear window section won't engage back into place. The issue has also affected the boot locking it and not allowing me access even thoough the roof was up! Side windows get stuck down. These are all intermittent problems. Taking it back to dealer this week but this is the second time it's occurreed the first was during the dealers demo run! BMW fixed it the. But clearly the issue remains. Does anyone have any similar experience of this? I've read some links on here and it appears a common problem. Just wondered how this was fixed in the end ???
Stark
Re: Hardtop roof issues. 2013 plate
Post by Stark » Fri Mar 27, 2015 8:28 am
I think I'd be the first to say it's not common. Most Z4 drivers are not members of this site, and of say 5% of members who may have had this same problem, then overall its a very very small % of E89 drivers. I, in 4 years, didn't have a single roof problem
Z4x40J
Post by Z4x40J » Fri Mar 27, 2015 8:31 am
Stark wrote:I think I'd be the first to say it's not common. Most Z4 drivers are not members of this site, and of say 5% of members who may have had this same problem, then overall its a very very small % of E89 drivers. I, in 4 years, didn't have a single roof problem
That's good news that it's not a common problem. Will see what the service centre does next week. However if anyone on here does have the same issue I'd be interested to hear what the solution was! :driving:
Stark
Post by Stark » Fri Mar 27, 2015 8:35 am
I'm sure you'll get it sorted and warranty is a great comforts.
The single biggest problem with the E89 has been alloys.....with a couple of exhaust and engine issues, very robust car otherwise
flybobbie
Post by flybobbie » Sun Mar 29, 2015 5:17 pm
Well that's covered everything...alloys, engine, exhaust and roof!
Even the ash tray has problems. Mine won't open unless I apply pressure to both the fore and aft edge of the flip up panel.
SO8
Post by SO8 » Mon Mar 30, 2015 4:31 pm
If you look at my post in this forum E89 re roof microswitch you will see mine suffered this and was quick to cure but a pain when it mucks about with the roof ...
Mine did all you have said and has been fine since the offending microswitch was replaced. I was told the switches are the usual thing that goes wrong. The 3 series had many issues with their clamshell roof but the E89 has in the main been sorted and it is not considered a significant issue in the grand scheme of things.
Mine is also a 2013 model btw.
viewtopic.php?f=45&t=75224
Current : BMW M240i Convertible in black and a Smart Fortwo diesel in white :)
Previous : BMW 35iS in Mineral White and an Mercedes AMG A45 in black
ruggedscot
Post by ruggedscot » Thu Apr 02, 2015 8:15 pm
Had this myself - micro switch issue and there are a few micro switches in there.....
2009 Z4 23Sdrive heated red leather satellite navigation
flybobbie
Post by flybobbie » Fri Apr 03, 2015 10:59 am
http://z4-forum.com/forum/viewtopic.php?f=45&t=73949
See the pics I took.
The wires to that microswitch seem badly positioned. Although my cars done 52k and looks fine.
I wonder if the cable tie has been causing some snagging on the wires if misplaced.
The microswitch wires enter the braided loom just below the cable tie.
SHarrison93
Post by SHarrison93 » Fri May 08, 2015 4:31 pm
I'm having the same issue with mine and hopefully taking it back in to the garage next week to have it looked at - i'll let you know what they say!
---- 2009 sDrive35i Black ----
flybobbie
Post by flybobbie » Fri May 08, 2015 9:09 pm
A lot of owners are not members of this site, so we don't know how common any problem is...only BMW know that.
zCruz_JAX
Post by zCruz_JAX » Fri Jun 19, 2015 2:59 pm
My 2011 35is (48k) has had this happen twice in a month. Fortunately the dealer is honoring the extended warranty I purchased. 1st time they said the wiring harness (drivers side) that extends up the the pillar from the trunk was pinched, and replaced the wire. The 2nd time they said it was the same thing on the passenger side. This time they are replacing the entire wiring harness/hydraulic line that extends up both sides. Its been over 2 weeks now, and will probably be another week before complete. What a pain !
Baza
Post by Baza » Sun Jun 21, 2015 4:27 pm
Had the same problem , symptoms exactly the same .As stated in earlier post a micro switch problem. As i am out of warranty i took it to an independent specialist for roof problems who fixed it with new micro switch. Works fine ever since.
Panther Kallista 2.8
S Drive 3.0i E89 2009 Space Grey Coral red Int 18" 295 wheels
Angie4m
Post by Angie4m » Mon Jun 22, 2015 8:52 pm
Baza wrote:Had the same problem , symptoms exactly the same .As stated in earlier post a micro switch problem. As i am out of warranty i took it to an independent specialist for roof problems who fixed it with new micro switch. Works fine ever since.
And this is why a lot of E89 owners are choosing to extend the warranty. We all know that the roof could cause issues at any point and it could be costly.
So if you are considering why you should extend the warranty this is probably the top reason. If you've got a 35i or 35is the DTC and the roof are probably going to be the 'biggies' unless you completely blow up the engine :cry:
Just out of interest, how much did an Indy charge up fix it?
Deep Sea Blue sDrive35is - I LOVE IT! Best car I've ever owned :) - Gone
RRS V8 Supercharged - Gone
Abarth 595 Competizione - Gone
Yas Marina Blue M4 Coupe - Gone
Current:
Protonic Blue i8
Amethyst 997
F56 JCW Challenge (19 of 52)
Still Shy and retiring
Baza
Post by Baza » Sun Jun 28, 2015 2:10 pm
Sorry for late reply been away without wifi, total cost £280.00 plus vat. Not cheap but probably less than a BMW garage,
flybobbie
Post by flybobbie » Sun Jun 28, 2015 9:43 pm
Would be interesting too know how and what they fix.
