Hi all,
With this spot of cold weather I have noticed a slight design fault with my Z4 and wondered if anyone else had experienced the same thing???
When the temperature drops to the point of freezing, it is nearly impossibly to get into my car!!! The doors seem to freeze shut and because the windows can't do their "going down" thing that they do prior to being able to open the door - you have to actually force the door open which sometimes takes a while and then when you try to shut the door the window is actually on the outside of the hard top!!!
If anyone knows what I mean please let me know if you have had the same problem!!!
Thanks,
Ames x
Problems opening Z4 doors when the temp drops!!!!
- littleone_90
SDrive 23i Atacama Yellow with Pure Design Impulse Interior AKA "BUMBLEBEE"!
- Wondermike
- Moderator
Re: Problems opening Z4 doors when the temp drops!!!!
Yep quite a few have had problems. I always thought that the window didn't need to drop to actually get the door open, but it does seal on the way back up again.
Problems getting into car when it’s frozen
I thought my car was immune, but alas yesterday it happened to me....
All hail Gummi Phledge... pop a bit on your door seals..
- ksher
The trick is to spray de-icer along the window frame before opening the door. I also use Rain-X to reduce ice on the glass.
Current BMW: 640d Gran Coupe M Sport (F06), 118d SE (F20).
Previous BMW: Z4 sDrive23i M Sport (E89), 318i Sport (F30), 120d SE (F20), Z4 2.5i Sport Roadster (E85), 523i Sport (E60), 323Ci (E46), 523i SE (E39), 318i (E36).
This has been posted before, my issue is not the rubber inside but ice outside.
All my zds have done this but this one is the worst when trying to shut the door, window gap is massive until it defrosts when i can reset the window.
stuff on the rubber never helped me never bothered with deicer, or using anything special and never had any issues resetting the window.
May give it a go though as this model does drop the window. My other zds had a hard top during the winter but never damaged the seal.
Happened with the wifes 120SE as well.
2012 BMW Z4 Sdrive2.3MSport,Saphire Black,Black Leather,19" Wheels, Sound Upgrade,Connectivity Pack,Wind Deflector,Parking Sensors, Heated seats and 6Cylinders
- jonnywells
This stuff is the nuts, although i have spent 100's on detailing kit this is defo 1 of the best things i have brought!Maniac wrote:All hail Gummi Phledge... pop a bit on your door seals..
2009 BMW Z4 sDrive35i - Havanna Metallic with Pure White Design Package - Light V spoke style 294 18"- Navigation system BMW prof - Heated seats - Electric seats with memory - Extended Lighting - Extended Storage - Electronic Folding Mirrors - PDC
