Engine Failure - Please contact BMW Immediately
- ryukin
Re: Engine Failure - Please contact BMW Immediately
Hi all, sorry for not getting back on here sooner! Thanks for all your replies and advice. I was told by a bmw technician that the z4 has a saddle tank and uses fuel from one side before a pump kicks in to transfer fuel over from the other side. He said the pump isn't transferring as much fuel as it should and my fuel gauge also needs re-callibrating. Basically, I need to take it in to the dealer. And you're right - it is under warranty (woohoo!) so will be a free fix. The original warranty ran out in May but I didn't realise you get a year's warranty with an AUC So, panic over.
That said, is 48 miles really that low? I never purposefully drive with a low amount of fuel and I fill up regularly, but in the 3 years that I owned my old zed there were a couple times on long unplanned drives that the fuel gauge went below 10 miles and it never cut out.
You'd think the gauge should be a little more accurate than being 50 miles out.
- bluestreak56
its just a calculated approximation based on current mpg stats the computer has made up, isnt it? I always calculate this myself anyway, working out what percentage of the fuel guage remains, how much that is in gallons, how many miles I need to travel and what mpg I think I will achieve..
Personally I try to fill up well before the white line on my cars and if possible at 1/4 tank. Primarily because I drive two much older cars (19 and 23 respectively) and dont want sludge / gunge / rust getting into the fuel line. I'm not saying these are there in the tank but why take the risk?
- EdP
ryukin, did your fuel pump made strange noises before this issue occured?ryukin wrote:He said the pump isn't transferring as much fuel as it should and my fuel gauge also needs re-callibrating.
- ryukin
Not that I noticed, why?EdP wrote:ryukin, did your fuel pump made strange noises before this issue occured?ryukin wrote:He said the pump isn't transferring as much fuel as it should and my fuel gauge also needs re-callibrating.
- EdP
One of the common E89 problems is the low pressure fuel pump, starting to make strange noises.ryukin wrote:Not that I noticed, why?EdP wrote:ryukin, did your fuel pump made strange noises before this issue occured?ryukin wrote:He said the pump isn't transferring as much fuel as it should and my fuel gauge also needs re-callibrating.
I have had replaced mine because the hum noise was quiet loud. The pump was still working properly, except the noise.
- AlanJ
ryukin wrote: The original warranty ran out in May but I didn't realise you get a year's warranty with an AUC
- Z4 Beemer
Errrrrrrrm....... the E89 was only launched in May 2009 so all of them should be within the 3 years factory warranty.
Current: 2016 Audi S3 :: Navarra Blue
Gone: 2009 Z4 sDrive 23i :: Deep Sea Blue
Gone: 2004 Z4 2.2i SE :: Maldives Blue
well once its calibraed it should be ok. still think its pants
if the fuel gage showns above a few points on the gauge should be ok
saying that i had a tt for 3 months before i go a full refund (long story and I would never ever have a tt or audi. Anyway the gauge states 1/3 the computer said ur out, and 3 miles from home and down a country road it died. needed a new head unit was on wathdog uk as out of wty was £600+ to replace, forge about sensors and pumps it was a faulty gauge and needed a compete computer head unit. mine was only 2 yrs and under wty,
- ryukin
Really? I bought it from a BMW dealership and they told me it only had 2 years warranty from new. Maybe he needs to be trained a little better...Z4 Beemer wrote:Errrrrrrrm....... the E89 was only launched in May 2009 so all of them should be within the 3 years factory warranty.
sounds like he was talking from his back-sideryukin wrote:Really? I bought it from a BMW dealership and they told me it only had 2 years warranty from new. Maybe he needs to be trained a little better...Z4 Beemer wrote:Errrrrrrrm....... the E89 was only launched in May 2009 so all of them should be within the 3 years factory warranty.
http://www.bmw.co.uk/bmwuk/owner/servic ... V0,00.html
realistically you should be getting an extra year warranty free of charge! as all AUC's come with 1 year warranty.
