Please help
B21 said:
RAYK47 said:
Thanks B21
Seems I was not looking in the right places as the new ones I found were about £350
Just noticed that these are repairs.
A refurb will be much cheaper…I believe it’s the MK60 abs fitted to E89s but you / they will check…
Yeah I guess you are right, unless I get a used one from eBay (refurb will be a much better option).
Are they easy to remove/replace? Will look on YouTube as well.
RAYK47 said:
B21 said:
RAYK47 said:
Thanks B21
FWIW I’d do a refurb ..your call..by BMW DIY standards pretty easy to do..need a programmer to bleed the system afterwards eg ISTA/Protool..
I don't think I have the ability to do my own refurb. Removing and installing I can possibly cope with though.
You misunderstood me..I’m suggesting you get a professional organisation to refurb it..not to buy a used eBay part…
:thumbsup:
I did a used unit off eBay and it’s still going strong, anymore issues and I’ll get a new one. As for the replacement process I simply undid the 4 bolts and swapped out the module itself! I did not touch the. Valve body as there was no issue with it.
booked mine into a BMW approved indi on March 3rd as if i need to recode and bleed brakes etc then that's above my ability.
One question i have is, i had a leak on the drivers side (rear window) and it made the carpet very wet. Could this cause a similar issue? Is there anything under there that could be affected by the water?
Yes there’s the longitudinal acceleration sensor for the DCS..
RAYK47 said:
ah, well i am getting DCS errors in ISTA
Well thats very strange..I'm disapointed BMW chose not to make this waterproof to 5 atmospheres...
ISTA should give you a more specifc diagnosis..
If you unbolty the seat, and remove the door trim you should be able to lift the carpet and see it..
Cheers, car is at my dads at the moment as it broke down there last (and as he has a driveway its best left there). Dont get a lot of chance to work on it due to time but hopefully i will get over there this weekend and look under the seat. :thumbsup:
I'm no E89 expert, so stand to be corrected, but the S 0085 No Communication with DSC stands out to me. If it can't communicate at all, wouldn't it stand to reason all the other DSC codes would pop up too.
Need a fresh clear then re read the codes..but it looks like the DSC is being taken down..we know if that happens almost everything else will then have issues..
Will get that done this weekend hopefully :thumbsup:
car has gone into the indy this morning. He was very concerned that it cant change gear, it tries but only 2nd is driving (even that seems to slip now and again).
I have a bad feeling that this is going to be very expensive. :x :cry:
My money is on the DSC unit..less than £200 to fix..plus labour :thumbsup:
