Convertible top does not work with new fob
2012 Bmw Z4 convertible top does not work with brand new key fob from Bmw, old key fobs battery was low and dealer suggested new key, still does not work. Works with key in door and works from inside car buttons? Help?
- Ole gits rule
Does the car have comfort access, do you need to insert the key and push the button to start the car?
Do you have two keys fob, if so is it working on the 2nd key?
Mine would not work off the key fob and the battery was the issue
M4 Vert in Yas Marina Blue
You can only open the roof off the key fob and not close it. Does it not even open the roof?
- Ole gits rule
I assumed this was opening the roof - battery in key fob seems odd as it will charge when you drive so unlikely to be that unless comfort access is fittedSilverstar wrote: ↑Thu Aug 12, 2021 7:34 pm You can only open the roof off the key fob and not close it. Does it not even open the roof?
i was told both my used key fobs that came with care were low on the battery and should go to BMW for new key fob, just picked up new key fob today, they said just put in key fob start car and that activates new fob, still does not work my convertible top.
Might need coding, anyone with carly live near OP?
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Scubaregs
Surely dealer that supplied fob should code it, if it needs doing?
- Ole gits rule
Do you have to insert the fob into the dash on the left of the steering wheel to start the car, if so this normally charges the fob as you drive.
Where did you get the car from?
- Zed Baron
Mine wouldn't do it also, was able to recode it to drop the roof using the fob using Carly (Pbondar did it actually )
- Nictrix
The battery in the fob was low so the dealer suggested a new fob?
Why not suggest charging the battery in the fob or in the case of a replaceable battery, a new battery?
It seems to me the dealer has robbed you.
- Ole gits rule
This is basically where I was heading with my questions, if the car has comfort access then a new battery and if no comfort access then put the fob in the slot and drive to charge.
I change my fobs over every 6 months to keep the both charged.
Op still hasn't said if he is expecting the roof to go up off the fob or if his issue is the roof not dropping
I would not be surprised if this is a vehicle battery issue
+1. Don't go there with worn tyres, they may sell you a new car.
Oh and BTW; hello and welcome
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
