e89 roof problem
OnlineOle gits rule
e89 roof problem
Car is in the garage, called the warranty company and told to take it to a VAT registered garage - roof is covered.
Guy had a quick look and said microswitch or hall sensor so a case of him running a full diagnostic and getting it fitted
M4 Vert in Yas Marina Blue
- RobbiZ4
e89 roof problem
Hall sensor would be wrong.Ole gits rule wrote: ↑Mon Jul 26, 2021 2:29 pm ... said microswitch or hall sensor so a case of him running a full diagnostic and getting it fitted
Could you post a first diagnostic result to verify?
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
OnlineOle gits rule
e89 roof problem
He did a quick diagnostic and said it was showing hall and microswitch errors but that was a 5 min job when I was there.
Will post when I know exactly what is up with it
e89 roof problem
I would not trust the checks 50%.
When my relays played up it said 5 sensors or limit switches were faulty.
When in fact only relay was faulty.
OnlineOle gits rule
e89 roof problem
I have told the guy that I think the issue is the microswitches - he is an ex BMW mastertech so I hope he knows what he is doing
- Zed Baron
e89 roof problem
Hope you get it sorted soon Sean
OnlineOle gits rule
e89 roof problem
Me to dude - should have some info this morning, he will do an hour diagnostic and then stop and call me as after that he needs my approval to continue but I have told him its 95% certain its microswitches.
- RobbiZ4
e89 roof problem
Microswitch coupling lock on both sides of the hydraulic rams in the boot. Not the microswitches in the roof shell!RobbiZ4 wrote: ↑Fri Jul 23, 2021 10:19 pm I'd say, same story as the following on the other Z4 channel:
https://e89.zpost.com/forums/showthread.php?t=1843991
OnlineOle gits rule
e89 roof problem
I believe so, only spoken with the receptionist at th moment but will have more info tomorrowRobbiZ4 wrote: ↑Tue Jul 27, 2021 9:45 pmMicroswitch coupling lock on both sides of the hydraulic rams in the boot. Not the microswitches in the roof shell!RobbiZ4 wrote: ↑Fri Jul 23, 2021 10:19 pm I'd say, same story as the following on the other Z4 channel:
OnlineOle gits rule
e89 roof problem
Car back and sorted, microswitches was the issue and it was the ones Robbie said.
Covered under warranty apart from £50 which I am happy to pay as any issues and back to the garage.
- Argyll Andy
e89 roof problem
Result, even with a small excessOle gits rule wrote: ↑Fri Jul 30, 2021 8:07 pm Car back and sorted, microswitches was the issue and it was the ones Robbie said.
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
OnlineOle gits rule
e89 roof problem
Yep, was £35 for the switches so for £15 I am happy to let some else mess with it.
Especially when I collected it and the roof would not budge, took them 45mins of messing to get it to go, they had to move the switch.
- RobbiZ4
e89 roof problem
Congrats!Ole gits rule wrote: ↑Fri Jul 30, 2021 8:10 pm Yep, was £35 for the switches so for £15 I am happy to let some else mess with it.
The problem is, that in most cases the faulty switch can't be measured with an ohm meter. The MS are not broken, but their timing doesn't fit anymore to the allowed tolerances.
One day it works fine, the other day the roof stops anywhere.
Excellent to recognize with my
e89 roof problem
I am not trying to be difficult, honestly, but I don't understand why that would be Robbie? As I understand it the bootlid ram microswitches are not functional until the last part of the bootlid (trunklid) cams pull the panel down and so momentarily make the switches. Why would this have a bearing on the whole process stopping randomly?
Also, why would an ohm-meter be useful to determine the operation of a switch? A continuity tester, I can see.
I am genuinely interested to gain more knowledge into how the process works, as I have a reasonable knowledge of electro-mechanics but know nothing about electronics.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
OnlineOle gits rule
e89 roof problem
That is what happened to me, worked force when I went out but played up when I came back - sodding pain as I do not have a garage but my neighbour does so I parked in there overnight as the windows were downRobbiZ4 wrote: ↑Fri Jul 30, 2021 8:42 pmCongrats!Ole gits rule wrote: ↑Fri Jul 30, 2021 8:10 pm Yep, was £35 for the switches so for £15 I am happy to let some else mess with it.
