Faulty roof
Faulty roof
My car developed the usual roof not opening problem , the rear section stopped working not opening , causing a fault , my local BMW dealer solve the problem apparently, now the car is back in the shop with the same problem and I have Just been told The problem is The rear windscreen needs replacing , why would this be anything to do with the mechanism of the roof , The dealer has told me that they are waiting for somebody to replace the rear screen , I have no idea what this has got to do with the mechanics of the of the boot any advice would be very welcome
- Chippie
Faulty roof
I would also question why the rear window would cause the roof not to open, most faults appear to be either micro switch faults or cable breaks. I wonder if it’s a case of “we’ll try this and see if it fixes it”
Faulty roof
The only relationship between the rear screen and the roof opening is that the rear screen heater is commanded off when stowing the glass panel in the boot!
- tintoverano
Faulty roof
can you get the fault codes from them? it is strange for sure
also you could try to get second opinion?
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
Faulty roof
I'll offer that.......it's broke.tintoverano wrote: ↑Sat Jun 05, 2021 7:08 am can you get the fault codes from them? it is strange for sure
Faulty roof
When I did my own diagnostics it came back with microswitch faulty . I don’t want the rear screen replacing if it’s not necessary , you would think they knew what they were doing, Unless they have damaged it somehow in the repair process.
Faulty roof
You need to invest in a code reader, buy one with lead attached. Can get for about 20 quid, worth their weight in gold.
Then let us know what is says. They sometimes don't tell you a specific fault, but lead in the right direction.
My £130 Foxwell reader paid for itself. Told me of salmon relay and broken wire faults.
Knowing i paid 18k for a car, 130 for code reader is peanuts.
Faulty roof
Sounds good. which Foxwell model is it?
2012 Z4 2.0 M-Sport Atacama Yellow
2000 Z3 3.0
2016 Vauxhall GTC Sunny Melon Yellow
2000 Jaguar X308 Sovereign 4.0
1969 Jensen Interceptor 6.3 litre
2000 Z3 3.0
Faulty roof
https://www.foxwelltool.co.uk/wholesale ... nt530.html
Faulty roof
Thanks for all the comments guys , Lloyd bmw i’ve just got back to me after questioning why they had to replace the rear window , they have admitted to damaging the screen when working on the roof and have to have it replaced
- Ole gits rule
Faulty roof
I assume they are covering the cost of this now you have asked a few questions and they have admitted liability?
What was their plan before this - get you to think the switch was part of the roof issue and have you pay for the rear window or how would they explain the missing cost on the invoice?
Think I may be avoiding them in the future
M4 Vert in Yas Marina Blue
Faulty roof
They are covering the cost of the new window . But I am still not happy I just hope I don’t end up with leaks , and all the other work is covered by extended warranty .
- Zed Baron
Faulty roof
Fills you with confidence that a BMW dealer with access to all the correct diagnostic information/equipment/tools can make a mistake like this.
Faulty roof
When I said I wasn’t happy I got the reply “these things happen sometimes “
