Misfires
tiglon
Misfires
Post by tiglon » Fri May 21, 2021 7:10 pm
That's outrageous, they really don't have the authority to confiscate your car.
As for the original topic, call me cynical, but that explanation from the dealer could be interpreted as "we c0cked something up last time and don't want to admit it so here's a just about plausible explanation that doesn't make us look bad".
2014 E89 35is Valencia Orange 788M wheels (M2 Competition), E90 M3 control arms, Eibach Pro Kit Springs, MHD Stage 1
ronk
Misfires
Post by ronk » Fri May 21, 2021 7:28 pm
I think it’s an industry standard scam!
Our local Vauxhall dealer tried it on my daughter - they didn’t mention worn pads again.
Busterboo
Misfires
Post by Busterboo » Fri May 21, 2021 9:00 pm
Pbondar wrote: Fri May 21, 2021 6:51 pm All noted thanks..
An unusual for an N54 reason for a misfire AFAIK ...
Yes, I think you're right.
Just to re-cap, the car began to misfire a little when accelerating fast, then misfiring badly after starting. The AA took it to the AD, where it had new injectors, after which it ran well for 3 months. Then it began to misfire again when accelerating fast. The indy put in new plugs & coil packs, which didn't cure the problem. Finally, as I've reported above, the AD replaced the rocker cover gasket and the car's running sweet as a nut.
Whether the AD's done something else, I don't know, because it's not reported in the invoice, nor did the AD reception staff mention any other work.
Vidi, vici, veni
Pbondar
Misfires
Post by Pbondar » Fri May 21, 2021 10:27 pm
Smartbear wrote: Fri May 21, 2021 6:54 pm
An unusual for an N54 reason for a misfire AFAIK, can add it to the repertoire of things to check in that event :thumbsup:
You can see why people get anxiety attacks going to AD for anything but servicing.
My Volvo dealer wanted £1,500 to change front n rear discs n pads and wouldn’t release the car because at 5mm pad left it ‘wasn’t safe’
That almost sounds like blackmail, did you manage to persuade them to return it?
Hi Rob, I did get it back but only by escalating the situation to the general manager… :headbang:
To be fair when I later had an issue with MAP and temp sensors they cooperated much better…by then if you are talking to them about fault codes from your reader they may suspect you are not a newbie… :tumbleweed:
Busterboo
Misfires
Post by Busterboo » Sat May 22, 2021 7:17 am
Busterboo wrote: Fri May 21, 2021 6:30 pm ... The overall total was £2,679.28. :)
This was paid by my BMW Insured Warranty.
The cost to me was my excess of £250.
Vidi, vici, veni
R.E92
Misfires
Post by R.E92 » Sun May 23, 2021 9:22 am
Leaking valve cover wouldn't cause the misfire. They either fixed a mistake they made or the issue is still present.
Busterboo
Misfires
Post by Busterboo » Sun May 23, 2021 10:30 pm
R.E92 wrote: Sun May 23, 2021 9:22 am Leaking valve cover wouldn't cause the misfire. They either fixed a mistake they made or the issue is still present.
Sadly, I think you're probably right.
Worse still, if the fault recurs, I'm stuck in a city with an AD and only one (reputably good) indy, neither of whom has cured it. That said, the AD claim they have, so at least I'll be able take it back to them.
Vidi, vici, veni
ronk
Misfires
Post by ronk » Sun May 23, 2021 10:43 pm
I thought the fault codes stayed resident until wiped?
flybobbie
Misfires
Post by flybobbie » Mon May 24, 2021 8:14 am
Replacing a gasket cured a misfire...more likely disturbing the plug wires cured the problem.
Even seen one guy on you tube not fit the plug back on properly caused a misfire, it wasn't fully clipped on.
Busterboo
Misfires
Post by Busterboo » Mon May 24, 2021 10:53 am
On the plus side, I don't think it's my imagination that the £250 on new DCT gearbox oil was money well spent. The changes were good before: now they're almost imperceptible.
Vidi, vici, veni
Smartbear
Misfires
Post by Smartbear » Mon May 24, 2021 11:46 am
ronk wrote: Sun May 23, 2021 10:43 pm I thought the fault codes stayed resident until wiped?
What fault codes? :?
e85 3.0si sold
ronk
Misfires
Post by ronk » Mon May 24, 2021 2:10 pm
Smartbear wrote: Mon May 24, 2021 11:46 am
Wouldn’t a misfire generate a fault code in a module?
Busterboo
Misfires
Post by Busterboo » Mon May 24, 2021 3:30 pm
Not a reply, but just for information. The car would not record a misfire or multiple misfires unless the engine light came on.
(The indy read the code and cleared the record of the fault, but was unable to stop the misfires reoccurring. So, before taking the car to the AD, I had to make sure there was a fault showing. By this time, I knew how to make the car misfire - which the indy hadn't done during his final test - and the AD then had proof of the fault.)
Vidi, vici, veni
ronk
Misfires
Post by ronk » Mon May 24, 2021 3:47 pm
At least you knew where you were with a distributor points and HT leads (often stranded :rofl: ) but throw £20 at the problem and if was fixed for a few months before the tinkering had to start again! :rofl:
Smartbear
Misfires
Post by Smartbear » Mon May 24, 2021 5:06 pm
ronk wrote: Mon May 24, 2021 2:10 pm
Not always, an odd occurrence wouldn’t be flagged up unless it went past a certain threshold :thumbsup:
e85 3.0si sold
