Boot Water Ingress - The journey of roof motors, hydro pump and seals
My existing battery is the Bosch S5 A08 AGM. If anyone knows of something better then welcome the input. Will be ordering tomorrow...
As I am now the proud owner of a Foxwell I will be looking to use that to register it. Will update the thread.
So, almost there
So, almost there
Z4 E89 35i M Sport - 2010
Crimson Red with Cream Leather
Fully loaded
Fully loaded
Thst's the same one I fitted when I got my E89 2 years ago to replace what looked like the original battery.
There are plenty of others recommended, Tayna seems popular, but shopping around I found that the price difference was marginal.
Cheers!
Andy
Thanks Andy, I checked and I bought it from Tanya in November 2019 so on paper it should be ok but I’ve come this far I may as well swap it for the same again.
Fully loaded
Fully loaded
And on it goes....
So today I drove in the rain, got home and checked for any sign of water. Now recall the offside rear vent was the one with the poor light gasket seal and bent bodywork near the vent. That all seems dry.
Near side is a different story, if you look at the top of this photo you will see water ! The two drops top right came off my hand.
- 3CB4D269-D643-43F0-A6D7-41693F84D1C2.jpeg (175.97 KiB) Viewed 932 times
Fully loaded
Fully loaded
The electronic box in this side is the TV module, it’s bolted down but slightly raised which is just as well.
- 0E397A47-D4B7-4C66-9089-B0FC56470BA1.jpeg (104.96 KiB) Viewed 932 times
- 0E35A73B-EB04-4A1C-89A5-440F5F757653.jpeg (107.9 KiB) Viewed 932 times
Fully loaded
Fully loaded
Looking at the new light gasket it all seems in good order, looks like I fitted it ok, no obvious signs of water coming through here.
- 687A6D58-830D-47DE-9E3B-4588028819E7.jpeg (180.38 KiB) Viewed 931 times
- 95074D35-9972-4C7D-BD1A-E878FE3BE309.jpeg (159.98 KiB) Viewed 931 times
Fully loaded
Fully loaded
Same goes for the new rear vent, seems dry all round and this was a good tight fit/seal when I did this one.
- 16CD3995-4A1F-4A30-A373-D630A11E2C4D.jpeg (104.96 KiB) Viewed 931 times
Fully loaded
Fully loaded
Maybe it’s the grommet, has anyone on here used chalk or something else to try and spot where the issue is? If so what did you use ?
Fully loaded
Fully loaded
Also notice very small amount near the battery, looking through the two holes I can see water but maybe it’s ok there and no real issue...
Fair to say I have just about have enough of this now
- 179AAAC3-8070-42F5-8DC7-727010C4F24D.jpeg (82.81 KiB) Viewed 930 times
Fully loaded
Fully loaded
Have you checked the top boot seal(up near the hinges) These go brittle allowing water to drip in and yours is quite old... I'll see if I can find my picture..
Thought i had checked everything but maybe I missed something.
Fully loaded
Fully loaded
Look here... thats where mine came in...
Thank you
Hmm it’s possible, I mean it looks fine condition wise and does feel brittle but some possible signs - it’s been parked for several hours now so could have dried out.
- 34E1DF3E-2254-4C36-A001-B137044C51C6.jpeg (87.81 KiB) Viewed 916 times
- B44051C5-5B44-47AB-99E2-C7776E925435.jpeg (88.62 KiB) Viewed 916 times
Fully loaded
Fully loaded
Looks like water marks but no sign of any
Looks like I’ll be ordering one of these now
Fully loaded
Fully loaded
Did you replace yours yourself? If so will I need some kind of sealant or does it come with some?
Thanks for your help, appreciated
Fully loaded
Fully loaded
