Boot Water Ingress - The journey of roof motors, hydro pump and seals
Hi Folks,
I have owned my 35i for around 6 years and never had a problem, until two days ago. Red light on the roof button, checked the boot and found water, mainly in the battery area.
BMW diagnosed and are saying the motor and pump will need to be replaced, c£2.5k for the part 5437 7309 634. The error is A6A3 which I believe is a temperature sensor (not the outdoor temp but hydrolic temp).
I can get hold of a refurb motor but not with the pump, would anyone know if the temp sensor is located in the pump or the motor as I might just take a shot at replacing it myself. My Zed is a 2010 so its the three solenoid version, not the 4 solenoid which I think came in c.2012.
Many thanks
Steve
Many thanks
Steve
Z4 E89 35i M Sport - 2010
Crimson Red with Cream Leather
Fully loaded
Fully loaded
E89 Roof Diag Error A6A3 temperature sensor - where is it?
I belive the temperature sensor is actually for the motor temperature, the reason I say this is that if you look at the wiring diagram (at least for my 23i) the temp sensor wires are purple and if you are to remove the motor you will see that the purple wires go into the motor and onto the circuit board inside it.
I too had this fault after water ingress, I took the cover off the motor, carefully cleaned everything up (used contact cleaner on the circuit board) dried everything off with compressed air and reassembled problem went away (touch wood)
Thank you so much for the replies. I also just confirmed with this when looking into motor (without pump) recons. My plan now is to collect the car back from the dealership and see if I can get any life out of it, then if that fails swap just the motor and go from there. I hope the error codes clear if the fault is removed as I don’t have an OBD2 scanner/command tool. Will keep the forum posted.
Fully loaded
Fully loaded
Hmm maybe I should get a Foxwell or something which can deal with roof codes. so I can just get on with things. I dont have a Windows PC (only Mac) so Open source software route is probably a non-starter.
Fully loaded
Fully loaded
- Chippie
Good luck with getting it fixed, I’d definitely advise getting some sort of scan tool or ISTA for the laptop, it will soon pay for itself with the cost of just one visit to garage for diagnostics and could save you hundreds of pounds over the Zeds ownership.
Thank you for the advice, would you know if Foxwell units, or another brand maybe, detect and reset roof related codes ? I’m struggling to find a definitive answer in the foxwell site. I’d rather not go software/laptop route.
Fully loaded
Fully loaded
I would buy Foxwell it's invaluable. Buy with BMW loaded. There is also included generic for other vehicles which is handy.
Problem with software and cables you never know what's going wrong if it doesn't work.
I had i think ISTA on laptop, worked eventually but took ages to load with ghost drives, dodgy cables, too much hassle.
You can do various things, reset code faults, reset service schedules, see realtime engine parameters.
See roof switches operate real time.
Mine has easily paid for itself, i keep it in the glove compartment.
Cheapest i have seen £117.
Perfect thank you, I will order one now
Fully loaded
Fully loaded
Foxwell NT520 Pro.
https://www.obdexpress.co.uk/wholesale/ ... TUQAvD_BwE
Think this is who i bought off year or so ago.
Done
Fully loaded
Fully loaded
Ok update on the motor replacement, I ordered a replacement from RoofMotors at cost of £300. It came with a bottle of oil (should I need to top-up, which I dont) and a seal. The advice was to stand upright with the pump reservoir at the bottom and remove the old motor. To make that a little easier I removed the battery and unplugged some of the electricals. With using a TX 20 torx there are just two bolts to undo. Removed the old motor, align the rotor of the new motor with the pump (I just had to turn 60 degrees) and replace two bolt, hook electrics back up and you are done. Takes 5mins. Some photos attached so you can see...
- Motor2.JPG (204.37 KiB) Viewed 6542 times
- Motor and pump 1.JPG (172.12 KiB) Viewed 6542 times
- Motor and pump 2.JPG (167.93 KiB) Viewed 6542 times
- Motor removed.JPG (175.85 KiB) Viewed 6542 times
- Motor1.JPG (152.38 KiB) Viewed 6542 times
Fully loaded
Fully loaded
So with that done, no errors coming up I tried the roof. It lifted 1/4 of the way and then faulted. Tried to but it back down, goes all the way but wont latch. That also means the boot wont open (because it doesnt know the position of the roof) and the windows wont go back up. I have a Foxwell NT530 on order but looking at the tracking it was shipped from China, now at Heathrow distribution center. So my choice are now maybe to wait until the Foxwell arrives and see what errors come up OR go back to BMW dealership for next round of investigation. I called an independent and the next slot they have is 5th of May!! Does anyone know if the Foxwell unit can command the boot to open? I know there is a hack to send 12v to a wire and it pops but thats more hassle on top of everything else. Oh and I replace the two salmon solenoids so they should be out of the question.
Fully loaded
Fully loaded
this thread says you can with a foxwell..
viewtopic.php?p=1822104
Keep the faith! there's a few of similar roof/boot issues going on at the moment if you search on here and no doubt it'll be one the microswitches or broken cables (going on recent posts)
