When I had flat battery, mine turned out to be a duff alternator, it was going flat after I used Headlights next day it was flat. Quick test with a volt meter showed it was only charging at 12v so couldn't cope with what was being used when headlights used. New alternator sorted it and I bought a volt meter that can be plugged into the cigarette lighter socket to monitor its output.
https://www.ebay.co.uk/itm/12V-24V-LED- ... Sw5PJbD8E1
I later fitted a permanent digital volt meter in one of the vacant switch positions on the dash of my Z3 and also one on my Z4 both also have usb sockets in them for plugging in accessories power for them spliced into the cig lighter socket wiring.
Battery Flat Over Night
- colb
- DSC_0317.JPG (116.07 KiB) Viewed 411 times
- DSC_0058 usb pic small.png (1.46 MiB) Viewed 411 times
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- ronk
Ive had that scenario on a car some years ago - The alternator went duff and started to pull current.
Put an ammeter in line and check for -ve discharge when it all gone to sleep.
