Hi, i would like to use INPA & ISTA-D for E89
I tried many version unsuccessfully. Which version of INPA and ISTAD you use ?
Thanks in advance
INPA / ISTA-D working for E89. Need help please
- Phil40
E89 2011 Sdrive 23i manual Sapphire Black - France (sorry for my english level not perfect)
- tintoverano
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
I used the Ista download from Bimmergeeks. Don't recall where i got Inpa.
- Phil40
Well, i can launch "Vehicule Identification" (Vin and informations about my Z) but after in Control Unit Tree, i have weird names of modules and also i can't test each modules or can't launch operations (all buttons are empty or disabled).
Version of ISTAD used : Rheingold 4.18.32 (from UltraODB2 website selling Cable DCAN bought on Amazon)
All configuration about settings (Ediabas.ini / odb.ini) + Cable on Port Com 1 OK
I tried cable with eachpositions swtich : I turn around
Please help
Please help
- tintoverano
I suggest to use the SW from bimmergeeks or first replace the SP-Daten files and see if that helps
it seems to be data version issue
mSport 23i
- Phil40
OK thanks tintoverano, i try this afternoon and let you know
