Thanks again for all the advice I’m going to get it booked in for next week hopefully.
I assume it’s safer not to drive in the meantime?
Exhaust problem
Exhaust problem
Actually it’s not a major issue on a short term basis..it only happens after shutdown and doesn’t affect normal operations..the embarrassing bit is the smoke on start up...
Of course that’s assuming my diagnosis is correct...
Best to get it checked out with some one who knows N20 engines..
Exhaust problem
OP, did you get this problem sorted and if so what was it?
VW Golf GTI Edition 35
Previous E89 18i manual Msport LCI, remapped, 282 bhp 453nm torque, Supersprint exhaust, decatted, stubby, BMW Performance Big Brake Kit, Msport rear valance and diffuser, Inovit 19inch Vector alloys, Msport black grilles.
- Marbeck64
Exhaust problem
Sounds like it could be the valve stem seals. Oil will leak by them after running a while and after sitting for a while, on start up it gets burnt off. Hence the blue smoke on start up.
2010 BMW Z4 23i 6spd
Previous BMW's
2003 BMW 325iC manual
2006 BMW x3 3.0D auto
1999 BMW 328is manual
1995 BMW 318i manual
1986 BMW 325iC manual
Previous BMW's
Exhaust problem
Very unlikely...common in older designs but unheard of on the N20..I give 98% probability that it was the turbo non return oil feed pipe..
Exhaust problem
I wonder if the OP will ever update us as to what was causing the smoke?
