Roof issue
tintoverano
Roof issue
Post by tintoverano » Sun Jan 26, 2020 1:39 pm
RobbiZ4 wrote: Sat Jan 25, 2020 6:17 pm Doesn't matter, if the engine is running or not. The battery has to be in a good condition.
yeah, that's what I wanted to confirm asking :D
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
Silverstar
Roof issue
Post by Silverstar » Sun Jan 26, 2020 1:51 pm
RobbiZ4 wrote: Sat Jan 25, 2020 6:13 pm
Silverstar wrote: Sat Jan 25, 2020 5:59 pm ]I am going to ask a silly question but how do you check the pump fluid level?
There is a min/max label on the white reservoir of the pump. If its missing, the oil level should be exact on the middle of the reservoir. In general, no oil is required over the lifetime of the car, except there is a leak.
Thanks for the info RobbiZ4, one more question what would cause the fluid to leak and is there anything that you should do to ensure it does not leak in the future?
Silverstar
Roof issue
Post by Silverstar » Sun Jan 26, 2020 1:54 pm
Timmyboybunter wrote: Sat Jan 25, 2020 6:10 pm
Silverstar wrote: Sat Jan 25, 2020 5:59 pm I am going to ask a silly question but how do you check the pump fluid level?
Not silly at all - find the pump in front of the battery, remove the grey foam above so you can see it. Left hand side of the pump is a plastic reservoir - on the side of it nearest the back of the car are 'min' and 'max' marks - the fluid is easy to see through the plastic if you wobble the pump.
Many thanks I just checked it :thumbsup:
RobbiZ4
Roof issue
Post by RobbiZ4 » Sun Jan 26, 2020 4:00 pm
Pardon, je suis Allemand :oops:
:ant:
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Silverstar
Roof issue
Post by Silverstar » Sun Jan 26, 2020 7:12 pm
RobbiZ4 wrote: Sun Jan 26, 2020 4:00 pm
Silverstar wrote: Sun Jan 26, 2020 1:51 pm ... one more question what would cause the fluid to leak and is there anything that you should do to ensure it does not leak in the future?
Hydraulic hoses will break in the future as well as the seals of the hydraulic rams might get weak. Nothing else.
AFAIK nothing can be done in advance, except replacing all parts in time. And that "time" is between the age of 8 and 15. :evil:
Summary:
Dont worry, enjoy the car and call me if its required. :rofl:
:rofl: :rofl: :thumbsup:
enzed4
Roof issue
Post by enzed4 » Sun Jan 26, 2020 8:04 pm
Slight hijack of the thread: Does anyone know what would be a good glue/adhesive to fix the foam sound insulation that sits on top of the hydraulic pump? I tore mine about 90% through when removing it to replace the salmon relays. Fortunately the tear is directly under the black bar so is not visible, but I would like to repair it if possible. Thanks.
And good result on the new battery, OP :thumbsup:
Mine was replaced while still in Japan in 2017. Took a while to figure out the date. Someone had put a label with the date it was replaced on the battery - very helpful except they use the year the current Emperor started his reign, which at the time was H29 (29th year of Heisei era) - quick Google helped do the maths.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
Smartbear
Roof issue
Post by Smartbear » Sun Jan 26, 2020 8:23 pm
enzed4 wrote: Sun Jan 26, 2020 8:04 pm Slight hijack of the thread: Does anyone know what would be a good glue/adhesive to fix the foam sound insulation that sits on top of the hydraulic pump? I tore mine about 90% through when removing it to replace the salmon relays. Fortunately the tear is directly under the black bar so is not visible, but I would like to repair it if possible. Thanks.
Does that make it the year of the battery? :P
e85 3.0si sold
enzed4
Roof issue
Post by enzed4 » Mon Jan 27, 2020 7:48 pm
Smartbear wrote: Sun Jan 26, 2020 8:23 pm
Overlooking that 'years of' are Chinese, that was still :roll: :lol:
Gone: 2010 35i DCT
Smartbear
Roof issue
Post by Smartbear » Mon Jan 27, 2020 7:52 pm
enzed4 wrote: Mon Jan 27, 2020 7:48 pm
Taxi for one! :rofl:
e85 3.0si sold
RobbiZ4
Roof issue
Post by RobbiZ4 » Mon Jan 27, 2020 8:23 pm
:ant:
