Pulling to right under acceleration
So the 35i is pulling to the right under acceleration. Best place to start? Tracking or suspension issues?
Have you checked tyre pressures?
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- buzyg
- MrPT
Can you tell whether it’s steering from the front or the back?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
How hard acceleration? Pulling away in traffic? Or tear-arsing?
Vidi, vici, veni
- Silverzedtom
I’d check tyre pressures as mentioned, brakes aren’t sticking by jacking and trying to spin the wheels and then I’d have tracking and bushes checked if all is well with pressure and brakes
E85 2.5si
F55 Cooper S
F55 Cooper S
Under any acceleration other than pottering about. Pulls at front to the right. Have to correct by steering left and on throttle back have to quickly correct to the right again.
Brakes etc all fine. So as per OP it’s really whether this could be caused by tracking or (and I feel more likely) suspension.
- kinger
I'd be looking for a broken spring, not exactly uncommon on our cars
Current - E89 35is Saphire Black
Previous- E89 35i Space Grey
Chuck my pennies worth in.
What about adaptive suspension, what is it like in different modes.
Could it be driven say over a speed hump one wheel at a time and see if the body motion changes.
Did you not have one of these changed under warranty some time ago?
- enuff_zed
Exactly the same symptoms I had with a 3 litre Capri (albeit on rear leaf springs).
Cracked through, but held together by the U-bolts and clamps!!!
I could overtake, then pull back in, simply by accelerating hard, then lifting off again.
So, I too initially thought broken spring?
It’s a thought yes. I had one replaced last year. They did say the other side is weeping.flybobbie wrote: ↑Sat Dec 28, 2019 9:32 pm Chuck my pennies worth in.
- ronk
My guess is bushing of the rear geometry - the application of power causing setback will cause a steering effect if one side was duff!
I can’t see how the application of power would cause any alteration to the front geometry If one strut was limp in either direction.
- ronk
Did you get this sorted?
Hey, No I’m getting it booked in this week.
