So, how did this happen, then?
Go to car, sense something wrong. Press fob. Heavier-than-normal pressure on handle 'trigger' and window doesn't drop the usual 2cm on opening door. Try to close door, can't. Try again, harder. Closes, but with little movement between latching and actual shutting. Then realise window top is outside roof.
Remember watching Turkish traffic policeman opening locked BMW to tow away. Big screwdriver between window and roof. Has someone tried this on mine? Think … go to passenger door. Ditto, window shut but outside roof. (But no fingerprints/smudges on either window or marks on doors.)
Get into car, shut door, try to operate front windows. Nothing. Rears fine. Try roof. Nothing. Search for faults on on-board computer. 'No Faults.' Manually check radio, CD, lights et cetera. No problems. Get out, shut door and realise can re-insert closed window under roof with firm thumbs. Do both, all looks fine, but … driver's window goes 'out' when I open door again. Decide to drive to gun club to ask someone to thumb windows closed with me inside to see if they'll work then … and to shoot.
Arrive, re-thumb driver's window shut, lock car with fob and walk to Reception. Oscillator on DTL clay trap broken. No shooting. Double bo//ocks. Go back to car. Press fob to open. Handle fine. Windows do usual initial drop. Get in, windows rise normally into correct position. Try to open & close fronts, no problem. Try roof, no problem. Drive home, try all again, no problems. Tried again just now. Fine.
So, how did this happen, then ? What caused it?
(I think I know and the answer's not electrical. A clue is that I have a very strong neighbour I collected from A&E yesterday.)
Vidi, vici, veni
Well, maybe not related, but when I reconnect battery on our 2008 Volvo C70 after disconnect, it takes a few 'cycles' before the windows will do their normal 'drop' on opening the doors. Similar when the battery was starting to go. So electrical disturbances on that car cause what you experienced. Battery all good?
2011 sDrive 35i Alpine White
100,000 miles 3rd owner
Other BMW is a 2016 C650 Sport scooter-beast
The only time I've had this was when the windows were frozen, they didn't drop and I pulled the door open (it was hard to do). When I closed the door the window was outside the frame. Fortunately when it defrosted everything was ok.
Strange that both windows did that though, and I can't see how your neighbour could affect your drivers side...
Had this issue on disconnecting battery for intended swap..then when power re applied had that issue..engine start and then normal shutdown all ok
Could be the battery on its way out or corroded / intermittent connection on terminals..or IBIS faulty/thinking battery flat..
Strong neighbour slammed the door maybe?? Something to do with air pressure.
Mick
Mick
Couple of weeks ago got the glass over the door frame, the seat belt got jammed in the door.
The door closed but was a fraction open so the glass missed the seal.
Bingo! Or, at least, this is what I suspect.
He slammed the door harder than I've ever heard a door slammed before and I think the air pressure forced both windows out of their seals.
They're fine now and both doors open & close normally. Next time I give him a lift, I'll play the chauffeur.
Vidi, vici, veni
- Smartbear
But there shouldn’t be any meaningful air pressure Buster, don’t forget the windows stay down a touch until the doors closed, allowing any residual pressure to escape before it can blow your eardrums/windscreen etc out.Busterboo wrote: ↑Mon Oct 21, 2019 2:13 pmBingo! Or, at least, this is what I suspect.
e85 3.0si sold
I understand the system, Rob, but I think the force he applied may have defeated it.
That apart, the engine was running when he slammed the door and was driven for another 15 minutes before I put the car in the garage. So, if there was a low battery problem, it happened after that and meant that both windows dropped and then rose outside the top seals in the garage. In these circumstances, I can understand them dropping if there were a low battery, but not dropping and rising, not least because the latter needs quite a lot of energy.
What do you think?
Vidi, vici, veni
- enuff_zed
Hmm, I think Rob's point is that the windows drop when you first open the door and do not rise again until the door is shut. They don't go up again once the door is open. I know this as it continually frustrates me, trying to clean and dry the bottom half inch of glass!Busterboo wrote: ↑Mon Oct 21, 2019 4:23 pmI understand the system, Rob, but I think the force he applied may have defeated it.
What do you think?
Therefore, unless your friend opened the door, exited and shut it all again within about half a second, there should have been a gap?
Were you in the car at the time, with your door shut?
Even if he had generated enough pressure, it would then have had to force your driver's door window out from it's seated position.
Would love to be proved wrong, but I feel your supposition may be masking a different issue................. which you'll never know unless it happens again.
- enuff_zed
So, in short, although it's a bit of a 'pane', you'll need to wait for another window of opportunity.
Slightly off topic, regarding cleaning the windows and the glass dropping half an inch. I saw in a video by White Details that you can actuate the lock manually to fool the car into thinking the door is shut and hence the windows will rise all the way to the top allowing you to clean that bottom half an inch. Basically using a screwdriver you manually actuate the lock with the door open and once you finish cleaning just pull on the door handle and the lock will release. Not sure if I explained that well!enuff_zed wrote: ↑Mon Oct 21, 2019 4:45 pmHmm, I think Rob's point is that the windows drop when you first open the door and do not rise again until the door is shut. They don't go up again once the door is open. I know this as it continually frustrates me, trying to clean and dry the bottom half inch of glass!Busterboo wrote: ↑Mon Oct 21, 2019 4:23 pmI understand the system, Rob, but I think the force he applied may have defeated it.
What do you think?
Your neighbour sounds like a right one, I wouldn't let him near my car if he slams the door that hard. Tell him to bloody walk
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- enuff_zed
That's worth a try. Cheers.Silverstar wrote: ↑Mon Oct 21, 2019 5:47 pm Slightly off topic, regarding cleaning the windows and the glass dropping half an inch. I saw in a video by White Details that you can actuate the lock manually to fool the car into thinking the door is shut and hence the windows will rise all the way to the top allowing you to clean that bottom half an inch. Basically using a screwdriver you manually actuate the lock with the door open and once you finish cleaning just pull on the door handle and the lock will release. Not sure if I explained that well!
Thanks all.
If it happens again, I'll get a new battery.
Vidi, vici, veni
